Date/Time: Mon, 29 Apr 2024 15:14:24 +0000
Alert Log/Manager
View Count: 915
[2018-11-28 23:06:51] |
User798620 - Posts: 29 |
Is it possible to clear only one alert from the alert log and leave the others? i can find the option under "Edit"-"Delete Alert" but when i click delete alert it does nothing even if the alert is highlighted, is this something you could add?
[2018-11-29 01:28:12] |
This will be added.
[2018-11-29 01:37:34] |
Thank you So Much the other thing i cant delete is when it says Web service response... dont know what it is, but that would be nice to get rid of as well. seeing as its not an alert. how often do things like this get updated?
