Date/Time: Sun, 05 May 2024 12:03:34 +0000
Numbers Bars Candle Offset Feature
View Count: 1320
[2018-11-28 13:45:47] |
User23386 - Posts: 43 |
I am looking to plot a simple candle to the left of the delta bars in sierra. As of yet I am unable to do this. I have tried 3 different attempts do get the finished look I want to no avail. I do not like to trouble sierra as I know you are busy. Does sierra numbers bars have an offset feature for both right side and left side of the candles so I can plot the delta bars to the right side of each candle using an adjustable right side candle offset distance as per my 2 screen caps on the right. http://www.sierrachart.com/image.php?Image=1543412302834.png |
Sierra Delta Bars Candle Bar Offset Feature.png / V - Attached On 2018-11-28 13:33:25 UTC - Size: 59.23 KB - 537 views |
[2018-11-28 18:24:35] |
You can set the Column 1 Background Type input with the Numbers Bars study to Right Aligned Volume Profile. That really is all we can suggest. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-28 18:24:54
