Date/Time: Tue, 07 May 2024 05:34:07 +0000
ZL price format
View Count: 540
[2018-11-28 12:16:47] |
natanibz - Posts: 131 |
Hello, with SC real time data feed the ZL price format is 0.2767 but with SC historical data is 27.67 (this is right) Also if i set the price format to .01 with SC real time data feed the price is not right: it is 0.28 How can i set the right price format (27.67) with SC real time data feed? (in have an account with Gain capital/OEC) Thanks Date Time Of Last Edit: 2018-11-28 12:20:55
[2018-11-28 17:14:23] |
We have looked into this, and the format of .0001 is from Gain Capital. That is set by them. You can alter the Multiplier and Tick Size settings: Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-28 18:46:13] |
is it possible,in this way, to set the right price format? Thanks |
[2018-11-28 19:43:16] |
Yes by setting both the historical and real-time multipliers to 100. And adjusting the tick size and Price Display Format accordingly.
