Date/Time: Fri, 03 May 2024 01:33:39 +0000
Problem with SCALE_SAMEASREGION
View Count: 553
[2018-11-28 10:37:20] |
User470516 - Posts: 78 |
Dear SC Team, I have developped a study that requires the scale to be set as "same as region". When I do this manually using the "scale" button of the settings windows, it works fine. When I include the instruction "sc.BaseGraphScaleRangeType = SCALE_SAMEASREGION;" then the entire window becomes empty and more annoyingly even if I have removed the study, the price themselves have fully disappeared. The header of the window still indicates the symbol installed but I am uncapable of displaying the prices. Using the "hand" to locate prices which seem to have moved far above is not working on the vertical axis although it does along the x-axis. I have the latest version intalled of SC. Would you have any suggestion? Thank you for your support. Regards, Laurent |
[2018-11-28 17:30:16] |
That is not the right variable. You need to use: ACSIL Interface Members - Variables and Arrays: sc.ScaleRangeType And you need to now correct the scale for the main price graph through the Scale Window: Chart Scale and Scale Adjusting: Opening the Scale Settings Window for the Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
