Date/Time: Mon, 06 May 2024 15:54:49 +0000
Commissions - global symbol settings
View Count: 1140
[2018-11-27 23:27:31] |
sierrasimon - Posts: 51 |
Hi, I dont have the field for commissions. I found another post with the answer, it shoud be there (attached screenshot). Where can I aktivate commissions to see them in trade activity log?
commissions.JPG / V - Attached On 2018-11-27 23:27:17 UTC - Size: 109.29 KB - 326 views |
[2018-11-28 01:49:13] |
That screenshot you attached, is that from your copy of Sierra Chart?
[2018-11-28 12:34:08] |
Yes it is.
[2018-11-28 17:36:28] |
You need to use the Round Turn Commission setting which is documented here: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#SymbolSettingsControls Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
