Date/Time: Fri, 18 Jul 2025 23:00:18 +0000
ACSIL: Example build script using udp commands to unload / load dlls
View Count: 2898
[2018-11-27 04:48:55]
User654912 - Posts: 26
You will need to adapt this to your system.
You will need to have installed the compiler from Sierra Chart.
Save this file as build.ps1 and run it from powershell with: .\build.ps1
function Send-UdpDatagram
Param ([string] $EndPoint,
[int] $Port,
[string] $Message)
$IP = [System.Net.Dns]::GetHostAddresses($EndPoint)
$Address = [System.Net.IPAddress]::Parse($IP)
$EndPoints = New-Object System.Net.IPEndPoint($Address, $Port)
$Socket = New-Object System.Net.Sockets.UDPClient
$EncodedText = [Text.Encoding]::ASCII.GetBytes($Message)
$SendMessage = $Socket.Send($EncodedText, $EncodedText.Length, $EndPoints)
$Socket.Close()
Send-UdpDatagram -EndPoint "127.0.0.1" -Port 22903 -Message "RELEASE_DLL--C:\SierraChart\Data\mydll.dll"
cmd.exe /c "C:\SierraChart\Data\VisualCCompile.Bat"
Send-UdpDatagram -EndPoint "127.0.0.1" -Port 22903 -Message "ALLOW_LOAD_DLL--C:\SierraChart\Data\mydll.dll"
Date Time Of Last Edit: 2018-11-27 04:50:11
[2018-11-28 01:06:59]
TedMar - Posts: 191
If u use MS Visual Studio , u can Build exe for Pre and Post Script
1. Build udppre.exe
#ifndef UNICODE
#define UNICODE
#endif
#define WIN32_LEAN_AND_MEAN
#include <winsock2.h>
#include <Ws2tcpip.h>
#include <stdio.h>
// Link with ws2_32.lib
#pragma comment(lib, "Ws2_32.lib")
void main()
  WSADATA wsaData;
  SOCKET SendSocket;
  sockaddr_in RecvAddr;
  int Port = 22903;
  int BufLen = 128;
  char SendBuf[] = "RELEASE_DLL--C:\\SierraChart\\Data\\myDLL.dll"; // --------- RELEASE_DLL ------------
  // Initialize Winsock
  WSAStartup(MAKEWORD(2, 2), &wsaData);
  // Create a socket for sending data
  SendSocket = socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP);
  // Set up the RecvAddr structure with the IP address of
  // the receiver (in this example case "127.0.0.1")
  // and the specified port number.
  RecvAddr.sin_family = AF_INET;
  RecvAddr.sin_port = htons(Port);
  RecvAddr.sin_addr.s_addr = inet_addr("127.0.0.1");
  // Send a datagram to the receiver
  printf("Sending a datagram to the receiver...\n");
  sendto(SendSocket,
    SendBuf,
    BufLen,
    0,
    (SOCKADDR *)&RecvAddr,
    sizeof(RecvAddr));
  // When the application is finished sending, close the socket.
  printf("Finished sending. Closing socket.\n");
  closesocket(SendSocket);
  // Clean up and quit.
  printf("Exiting.\n");
  WSACleanup();
  return;
2. Build udppost.exe
#ifndef UNICODE
#define UNICODE
#endif
#include <stdio.h>
void main()
  WSADATA wsaData;
  SOCKET SendSocket;
  int Port = 22903;
  int BufLen = 128;
  char SendBuf[] = "ALLOW_LOAD_DLL--C:\\SierraChart\\Data\\MyDLL.dll"; // ------- ALLOW_LOAD_DLL --------
  sendto(SendSocket,
    SendBuf,
    BufLen,
    0,
    sizeof(RecvAddr));
  WSACleanup();
  return;
Ignore Warnings ...
3.) Add them both files in VS Pre /Post builid
https://docs.microsoft.com/en-us/visualstudio/ide/specifying-custom-build-events-in-visual-studio?view=vs-2017
call C:\phat-to-exe
4.) Set UDP port in Sierrachart (/Global Setin../Data...../SC Server Settings) and RESTART SC.
Date Time Of Last Edit: 2018-11-28 01:09:32
