Date/Time: Mon, 06 May 2024 12:47:03 +0000
Possible to enter scaled orders in a range on the chart?
View Count: 667
[2018-11-27 02:15:37] |
user8222 - Posts: 21 |
Hi, I am looking to use a feature such as picking two lines or a rectangle for support/resistance areas to scale orders between. For example, say I wanted to short bitcoin from $5000-5200. I would like to be able to draw a box and set a bulk amount of orders which progressively scale this range. I.e., 100 orders, each order 1% larger than the previous, or such. Is this possible to do directly on the chart? Thanks.
[2018-11-27 18:35:47] |
No, this is not supported directly in Sierra Chart. You would need to create your own custom trading study to do this using ACSIL. The documentation for creating a custom study can be found starting here: Advanced Custom Study Interface and Language (ACSIL) And refer to: Automated Trading From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-27 18:38:09
