Date/Time: Mon, 06 May 2024 07:56:13 +0000
h elp
View Count: 1170
[2013-11-05 15:40:00] |
HenryAndrechyn - Posts: 4 |
is it possible to use Ninja and sierra charts with TWS
[2013-11-05 16:02:28] |
Yes. Refer to the set up instructions here: http://www.sierrachart.com/index.php?l=doc/IB.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-05 16:25:55] |
can one use Ninja Trader along with Sierra Charts TWS without a conflict
[2013-11-05 16:41:31] |
Yes. You need to make sure that each program connected to the Interactive Brokers Trader Workstation uses a different Client ID number. The set up instructions explains this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-05 16:41:43
