Date/Time: Sat, 04 May 2024 09:53:07 +0000
[Locked] - Sierra Chart is very slow and i have no idea why
View Count: 1648
[2018-11-26 16:06:38] |
Cavalry3162 - Posts: 523 |
Hello SC, i am running SC on an 8 monitor setup and its really behaving slow, even though there is not a whole lot of cpu / gpu usage... is there a way to find out whats causing that issue? i have attached my chartbook, cpu as well as gdi count... please advise Date Time Of Last Edit: 2018-11-26 16:10:06
cpu_usage.png / V - Attached On 2018-11-26 16:03:51 UTC - Size: 89.26 KB - 564 views gdi_objects.png / V - Attached On 2018-11-26 16:03:55 UTC - Size: 31.79 KB - 563 views Private File |
[2018-11-26 16:10:47] |
here's the gpu load.. which alternates between 3% and 10%
gpu_load.png / V - Attached On 2018-11-26 16:10:31 UTC - Size: 44.19 KB - 402 views |
[2018-11-26 21:09:03] |
Most likely the issue is due to the high GDI Object count. Not sure why it is so high. It could be due to Fonts. The first step is we need to make sure the number of Fonts is limited and we will do that in the next release and then you can see if that helps bring the GDI Object count down substantially.
[2018-11-26 21:19:00] |
that sounds like a plan.. i also have a couple market profiles in my charts.. am not sure if that is an important info for you guys coz given the low cpu / gpu usage i thought its not really an issue..(?) |
[2018-11-27 09:54:42] |
This might only be indirectly relevant but is not a problem. Do you see a message in the Message Log that says this: "Notice: # fonts have been allocated".?
[2018-11-27 10:03:54] |
actually i do not see any of those messages.. as a reference here's one complete log right from the get go: Reading Internal Order ID file. | 2018-11-27 05:01:07 Reading Trade Orders file. | 2018-11-27 05:01:08 Reading Trade Positions file. | 2018-11-27 05:01:08 Account Balance file. | 2018-11-27 05:01:08 Listening on UDP port 22903. | 2018-11-27 05:01:08 Software version: 1847 64-bit | 2018-11-27 05:01:08 Usage end date: 2019-10-12 | 2018-11-27 05:01:08 Enabled for: Advanced Features. | 2018-11-27 05:01:08 Enabled for: Advanced Features 2. | 2018-11-27 05:01:08 Enabled for: Sierra Chart Historical Data Service. | 2018-11-27 05:01:08 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-11-27 05:01:08 Enabled for: INDEXES_DATA_BARCHART | 2018-11-27 05:01:08 Enabled for: CME (Trading Account Required) | 2018-11-27 05:01:08 Enabled for: CBOT (Trading Account Required) | 2018-11-27 05:01:08 Enabled for: COMEX (Trading Account Required) | 2018-11-27 05:01:08 Enabled for: NYMEX (Trading Account Required) | 2018-11-27 05:01:08 Enabled for: Eurex with Market Depth | 2018-11-27 05:01:08 Enabled for: CBOE Indices | 2018-11-27 05:01:08 Received 2 data feed usernames. | 2018-11-27 05:01:08 Allow Support for Sierra Chart Data Feeds is disabled. | 2018-11-27 05:01:08 Current selected Data/Trading service: Rithmic Trading | 2018-11-27 05:01:08 Chart Update Interval: 100 | 2018-11-27 05:01:08 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-11-27 05:01:08 2018-11-27 05:01:07 Local computer time | 2018-11-27 05:01:08 2018-11-27 10:01:07 Local computer time in UTC | 2018-11-27 05:01:08 2018-11-27 05:01:07 Local computer time in SC Time Zone | 2018-11-27 05:01:08 2018-11-27 10:01:09 Server time in UTC | 2018-11-27 05:01:08 Local computer UTC time and Server UTC time difference: 2 seconds. | 2018-11-27 05:01:08 Program path: C:\SierraChart\ | 2018-11-27 05:01:08 Data Files path: C:\SierraChart\Data\ | 2018-11-27 05:01:08 OS Version Number: 10.0 | 2018-11-27 05:01:08 Locale Setting: C | 2018-11-27 05:01:08 DLLs: AuctionVistaBubbles.dll, chartdir60.dll, chartdir60_64.dll, sceetobots.dll, sceetobots_64.dll, sst_FreeBundle.dll, sst_FreeBundle_64.dll, sst_pulling_stacking.dll, sst_pulling_stacking_64.dll, Trade29CustomStudies.dll, Trade29CustomStudies_64.dll, TradeVolumeStudies.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2018-11-27 05:01:08 Created the DTC Protocol server. | 2018-11-27 05:01:08 DTC Protocol Server listening on port 11099. | 2018-11-27 05:01:08 Created the DTC Protocol historical data server. | 2018-11-27 05:01:08 HD Server Manager | Listening on port 11098 | 2018-11-27 05:01:08 Checking for new symbol settings for service code rithmic.trading | 2018-11-27 05:01:08 HTTPS www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-11-27 05:01:08 HTTPS www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-11-27 05:01:08 Requesting symbol settings for service code rithmic.trading. Overwrite = on. | 2018-11-27 05:01:08 Received 5 login tokens. | 2018-11-27 05:01:08 Symbol settings received. | 2018-11-27 05:01:09 Processed 1055 symbol settings. | 2018-11-27 05:01:09 HTTPS www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-11-27 05:01:10 HTTPS www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-11-27 05:01:10 Files to Open on Start up | Opening file: 2018-10-24_Complete.cht | 2018-11-27 05:01:11 NISS-TF 1 Min #40 | Reloading chart. | 2018-11-27 05:01:11 NISS-NYSE 1 Min #2 | Reloading chart. | 2018-11-27 05:01:11 NQZ8-CME [CBV] 1000 Volume #4 | Reloading chart. | 2018-11-27 05:01:11 CLF9-NYMEX [CBV] 30 Min #6 | Reloading chart. | 2018-11-27 05:01:11 HTTPS login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-11-27 05:01:12 HTTPS login.sierrachart.com:443 (1) | Received socket Close event. | 2018-11-27 05:01:12 NQZ8-CME [CBV] #9 | Reloading chart. | 2018-11-27 05:01:12 NQZ8-CME [CBV] #11 | Reloading chart. | 2018-11-27 05:01:12 CLF9-NYMEX [CBV] 5000 Volume #12 | Reloading chart. | 2018-11-27 05:01:12 CLF9-NYMEX [CBV] 1 Min #13 | Reloading chart. | 2018-11-27 05:01:13 Loading DLL C:\SierraChart\Data\sst_FreeBundle_64.dll | 2018-11-27 05:01:13 Loading DLL C:\SierraChart\Data\TradeVolumeStudies.dll | 2018-11-27 05:01:13 NQZ8-CME [CB] #1 | Reloading chart. | 2018-11-27 05:01:13 CLF9-NYMEX [CBV] 1 Min #3 | Reloading chart. | 2018-11-27 05:01:13 NQZ8-CME [CB] 1 Min #5 | Reloading chart. | 2018-11-27 05:01:13 NQZ8-CME [CB] 5 Min #7 | Reloading chart. | 2018-11-27 05:01:13 HTTPS www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-11-27 05:01:13 HTTPS www.sierrachart.com:443 (2) | Received socket Close event. | 2018-11-27 05:01:13 RTYZ8-CME [CB] 1 Min #8 | Reloading chart. | 2018-11-27 05:01:13 ESZ8-CME [CB] 5 Min #10 | Reloading chart. | 2018-11-27 05:01:14 HTTPS www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-11-27 05:01:14 HTTPS www.sierrachart.com:443 (4) | Received socket Close event. | 2018-11-27 05:01:14 ESZ8-CME [CB] 1 Min #14 | Reloading chart. | 2018-11-27 05:01:14 YMZ8-CBOT [CB] 5 Min #15 | Reloading chart. | 2018-11-27 05:01:14 YMZ8-CBOT [CB] 1 Min #16 | Reloading chart. | 2018-11-27 05:01:14 NQZ8-CME [CBV] 5 Min #19 | Reloading chart. | 2018-11-27 05:01:14 ESZ8-CME 5 Min #20 | Reloading chart. | 2018-11-27 05:01:14 CLF9-NYMEX [CBV] 1 Min #17 | Reloading chart. | 2018-11-27 05:01:14 + Loading additional symbol data. | 2018-11-27 05:01:15 + Loading additional symbol data. | 2018-11-27 05:01:15 HTTPS www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-11-27 05:01:15 HTTPS www.sierrachart.com:443 (5) | Received socket Close event. | 2018-11-27 05:01:15 NQZ8-CME [CB] 1 Min #18 | Reloading chart. | 2018-11-27 05:01:16 HTTPS login.sierrachart.com:443 (1) | Signaling to core to close socket | 2018-11-27 05:01:16 HTTPS login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-27 05:01:16 HTTPS login.sierrachart.com:443 (1) | Closed. | 2018-11-27 05:01:16 NQZ8-CME [CB] #1 | Study: Display Forex factory calendar news items | Making HTTP request. | 2018-11-27 05:01:20 Chart: NQZ8-CME [CB] #1 | Study: Display Forex factory calendar news items | Requesting forex factory calendar data from a simplesystemtrading.com server. | 2018-11-27 05:01:20 * HTTP data.simplesystemtrading.com:80 (1) | Creating socket. | 2018-11-27 05:01:20 HTTP data.simplesystemtrading.com:80 (1) | Connecting to IP: 104.196.53.58. | 2018-11-27 05:01:20 HTTPS www.sierrachart.com:443 (2) | Signaling to core to close socket | 2018-11-27 05:01:22 HTTPS www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-27 05:01:22 HTTPS www.sierrachart.com:443 (2) | Closed. | 2018-11-27 05:01:22 HTTPS www.sierrachart.com:443 (4) | Signaling to core to close socket | 2018-11-27 05:01:22 HTTPS www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-27 05:01:22 HTTPS www.sierrachart.com:443 (4) | Closed. | 2018-11-27 05:01:22 Intraday data recording state for symbol TICKBA-NYSE is set to download 'Pending'. | 2018-11-27 05:01:22 NQZ8-CME [CBV] 5 Min #19 | Started historical data download for additional symbol TICKBA-NYSE. Download ID: 1 | 2018-11-27 05:01:22 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2018-11-27 05:01:22 NQZ8-CME [CBV] 5 Min #19 | Started historical data download for additional symbol NISS-NYSE. Download ID: 2 | 2018-11-27 05:01:22 HTTPS www.sierrachart.com:443 (5) | Signaling to core to close socket | 2018-11-27 05:01:27 HTTPS www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-27 05:01:27 HTTPS www.sierrachart.com:443 (5) | Closed. | 2018-11-27 05:01:27 HD Request # 2 | Downloading Intraday chart data for TICKBA-NYSE to the file TICKBA-NYSE.scid. Service: statscalc | 2018-11-27 05:01:31 HD Request # 2 | Download start date-time: 2018-11-27 05:00:46.000 | 2018-11-27 05:01:31 HD Request # 2 | Using server: ds4.sierracharts.com port 10149 | 2018-11-27 05:01:31 Socket (2) | Creating socket. | 2018-11-27 05:01:31 Socket (2) | Connecting to IP: 192.81.56.146. | 2018-11-27 05:01:31 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:31 HD Request # 2 | Sending historical data logon request message. | 2018-11-27 05:01:31 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:46. Record interval: 0. Symbol: TICKBA-NYSE | 2018-11-27 05:01:31 HD Request # 2 | Decompressing data. | 2018-11-27 05:01:31 HD Request # 2 | Receiving Intraday data for TICKBA-NYSE starting at 2018-11-27 05:00:46 | 2018-11-27 05:01:31 HD Request # 2 | Timestamp of first Intraday data file record written: 2018-11-27 05:00:47 | 2018-11-27 05:01:31 Socket (2) | Signaling to core to close socket | 2018-11-27 05:01:31 Socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:01:31 Socket (2) | Socket gracefully closed by remote side. | 2018-11-27 05:01:31 Socket (2) | Closed. | 2018-11-27 05:01:31 Chart #16 has tagged chart #8 for full recalculation. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:01:32 Chart #16 has tagged chart #8 for full recalculation. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:01:32 HD Request # 2 | Historical data for TICKBA-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-27 05:01:32 Historical data download thread signaled to stop. | 2018-11-27 05:01:32 HD Request # 2 | Received 45 records from 2018-11-27 05:00:46 to 2018-11-27 05:01:30 (44.0 seconds) and wrote 44 records for TICKBA-NYSE | 2018-11-27 05:01:32 HD Request # 2 | Completion time: 2s | 2018-11-27 05:01:32 HD Request # 2 | Intraday data download complete for TICKBA-NYSE. Unique request ID: 1 | 2018-11-27 05:01:32 Removed historical data download ID 1 | 2018-11-27 05:01:32 NQZ8-CME [CBV] 5 Min #19 | Historical data download for additional symbol TICKBA-NYSE with ID 1 has completed. | 2018-11-27 05:01:32 HD Request # 3 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2018-11-27 05:01:32 HD Request # 3 | Download start date-time: 2018-11-27 05:00:46.000 | 2018-11-27 05:01:32 HD Request # 3 | Using server: ds3.sierracharts.com port 10150 | 2018-11-27 05:01:32 Socket (2) | Creating socket. | 2018-11-27 05:01:32 Socket (2) | Connecting to IP: 65.182.172.42. | 2018-11-27 05:01:32 HD Request # 3 | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:33 HD Request # 3 | Sending historical data logon request message. | 2018-11-27 05:01:33 HD Request # 3 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:46. Record interval: 0. Symbol: NISS-NYSE | 2018-11-27 05:01:33 HD Request # 3 | Decompressing data. | 2018-11-27 05:01:33 HD Request # 3 | Receiving Intraday data for NISS-NYSE starting at 2018-11-27 05:00:46 | 2018-11-27 05:01:33 HD Request # 3 | Timestamp of first Intraday data file record written: 2018-11-27 05:00:47 | 2018-11-27 05:01:33 Socket (2) | Signaling to core to close socket | 2018-11-27 05:01:33 Socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:01:33 Socket (2) | Socket gracefully closed by remote side. | 2018-11-27 05:01:33 Socket (2) | Closed. | 2018-11-27 05:01:33 HTTP data.simplesystemtrading.com:80 (1) | Socket gracefully closed by remote side. | 2018-11-27 05:01:36 HTTP data.simplesystemtrading.com:80 (1) | Received socket Close event. | 2018-11-27 05:01:36 HD Request # 3 | Historical data for NISS-NYSE is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-27 05:01:38 Historical data download thread signaled to stop. | 2018-11-27 05:01:38 HD Request # 3 | Received 47 records from 2018-11-27 05:00:46 to 2018-11-27 05:01:32 (46.0 seconds) and wrote 46 records for NISS-NYSE | 2018-11-27 05:01:38 HD Request # 3 | Completion time: 5s | 2018-11-27 05:01:38 HD Request # 3 | Intraday data download complete for NISS-NYSE. Unique request ID: 2 | 2018-11-27 05:01:38 Removed historical data download ID 2 | 2018-11-27 05:01:38 NQZ8-CME [CBV] 5 Min #19 | Historical data download for additional symbol NISS-NYSE with ID 2 has completed. | 2018-11-27 05:01:38 HTTP data.simplesystemtrading.com:80 (1) | Signaling to core to close socket | 2018-11-27 05:01:38 HTTP data.simplesystemtrading.com:80 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-11-27 05:01:38 HTTP data.simplesystemtrading.com:80 (1) | Closed. | 2018-11-27 05:01:38 Intraday data recording state for symbol NISS-TF is set to download 'Pending'. | 2018-11-27 05:01:41 HD Request # 4 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2018-11-27 05:01:41 HD Request # 4 | Download start date-time: 2018-11-27 05:00:46.000 | 2018-11-27 05:01:41 HD Request # 4 | Using server: ds4.sierracharts.com port 10149 | 2018-11-27 05:01:41 Socket (1) | Creating socket. | 2018-11-27 05:01:41 Socket (1) | Connecting to IP: 192.81.56.146. | 2018-11-27 05:01:41 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:41 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQZ8-CME | 2018-11-27 05:01:41 Intraday data recording state for symbol NQZ8-CME is set to download 'Pending'. | 2018-11-27 05:01:41 HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:41 HD Request # 4 | Sending historical data logon request message. | 2018-11-27 05:01:41 HD Request # 4 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:46. Record interval: 0. Symbol: NISS-TF | 2018-11-27 05:01:41 HD Request # 4 | Decompressing data. | 2018-11-27 05:01:42 HD Request # 4 | Receiving Intraday data for NISS-TF starting at 2018-11-27 05:00:46 | 2018-11-27 05:01:42 HD Request # 4 | Timestamp of first Intraday data file record written: 2018-11-27 05:00:47 | 2018-11-27 05:01:42 Socket (1) | Signaling to core to close socket | 2018-11-27 05:01:42 Socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:01:42 Socket (1) | Socket gracefully closed by remote side. | 2018-11-27 05:01:42 Socket (1) | Closed. | 2018-11-27 05:01:42 HD Request # 4 | Historical data for NISS-TF is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-27 05:01:42 Historical data download thread signaled to stop. | 2018-11-27 05:01:42 HD Request # 4 | Received 57 records from 2018-11-27 05:00:46 to 2018-11-27 05:01:42 (56.0 seconds) and wrote 56 records for NISS-TF | 2018-11-27 05:01:42 HD Request # 4 | Completion time: 1s | 2018-11-27 05:01:42 HD Request # 4 | Intraday data download complete for NISS-TF. Unique request ID: 3 | 2018-11-27 05:01:42 Removed historical data download ID 3 | 2018-11-27 05:01:42 HD Request # 5 | Downloading Intraday chart data for NQZ8-CME to the file NQZ8-CME.scid. Service: cme | 2018-11-27 05:01:42 HD Request # 5 | Download start date-time: 2018-11-27 05:00:46.000 | 2018-11-27 05:01:42 HD Request # 5 | Using server: ds7.sierracharts.com port 10150 | 2018-11-27 05:01:42 Socket (1) | Creating socket. | 2018-11-27 05:01:42 Socket (1) | Connecting to IP: 8.18.161.133. | 2018-11-27 05:01:42 HD Request # 5 | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:42 HD Request # 5 | Sending historical data logon request message. | 2018-11-27 05:01:42 HD Request # 5 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:46. Record interval: 0. Symbol: NQZ18 | 2018-11-27 05:01:42 HD Request # 5 | Decompressing data. | 2018-11-27 05:01:42 Socket (1) | Signaling to core to close socket | 2018-11-27 05:01:42 Socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:01:42 Socket (1) | Socket gracefully closed by remote side. | 2018-11-27 05:01:43 Socket (1) | Closed. | 2018-11-27 05:01:43 HD Request # 5 | Historical data for NQZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-27 05:01:43 Historical data download thread signaled to stop. | 2018-11-27 05:01:43 HD Request # 5 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQZ8-CME | 2018-11-27 05:01:43 HD Request # 5 | Completion time: 1s | 2018-11-27 05:01:43 HD Request # 5 | Intraday data download complete for NQZ8-CME. Unique request ID: 4 | 2018-11-27 05:01:43 Removed historical data download ID 4 | 2018-11-27 05:01:43 Rithmic Trading | Using primary service for historical data for NQZ8-CME | 2018-11-27 05:01:43 HD Request # 5 | Download from primary service not started due to error. | 2018-11-27 05:01:43 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL?#-NYMEX pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:44 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLF9-NYMEX | 2018-11-27 05:01:44 Intraday data recording state for symbol CLF9-NYMEX is set to download 'Pending'. | 2018-11-27 05:01:44 HD Request # 6 | Downloading Intraday chart data for CLF9-NYMEX to the file CLF9-NYMEX.scid. Service: nymex | 2018-11-27 05:01:44 HD Request # 6 | Download start date-time: 2018-11-27 05:00:46.000 | 2018-11-27 05:01:44 HD Request # 6 | Using server: ds1.sierracharts.com port 10149 | 2018-11-27 05:01:44 Socket (1) | Creating socket. | 2018-11-27 05:01:45 Socket (1) | Connecting to IP: 8.18.161.135. | 2018-11-27 05:01:45 'Allow Support for Sierra Chart Data Feeds' is disabled. The RTY?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:45 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYZ8-CME | 2018-11-27 05:01:45 Intraday data recording state for symbol RTYZ8-CME is set to download 'Pending'. | 2018-11-27 05:01:45 RTYZ8-CME [CB] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:01:45 HD Request # 6 | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:46 HD Request # 6 | Sending historical data logon request message. | 2018-11-27 05:01:46 HD Request # 6 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:46. Record interval: 0. Symbol: CLF19 | 2018-11-27 05:01:46 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:46 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESZ8-CME | 2018-11-27 05:01:46 Intraday data recording state for symbol ESZ8-CME is set to download 'Pending'. | 2018-11-27 05:01:46 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM?#-CBOT pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:46 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMZ8-CBOT | 2018-11-27 05:01:46 Intraday data recording state for symbol YMZ8-CBOT is set to download 'Pending'. | 2018-11-27 05:01:46 HD Request # 6 | Decompressing data. | 2018-11-27 05:01:46 Socket (1) | Signaling to core to close socket | 2018-11-27 05:01:46 Socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:01:46 HD Request # 6 | Historical data for CLF9-NYMEX is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-27 05:01:46 Historical data download thread signaled to stop. | 2018-11-27 05:01:46 HD Request # 6 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for CLF9-NYMEX | 2018-11-27 05:01:46 HD Request # 6 | Completion time: 1s | 2018-11-27 05:01:46 HD Request # 6 | Intraday data download complete for CLF9-NYMEX. Unique request ID: 5 | 2018-11-27 05:01:46 Removed historical data download ID 5 | 2018-11-27 05:01:46 Rithmic Trading | Using primary service for historical data for CLF9-NYMEX | 2018-11-27 05:01:46 HD Request # 6 | Download from primary service not started due to error. | 2018-11-27 05:01:46 HD Request # 7 | Downloading Intraday chart data for RTYZ8-CME to the file RTYZ8-CME.scid. Service: cme | 2018-11-27 05:01:46 HD Request # 7 | Download start date-time: 2018-11-27 05:00:34.000 | 2018-11-27 05:01:46 HD Request # 7 | Using server: ds7.sierracharts.com port 10150 | 2018-11-27 05:01:46 Socket (2) | Creating socket. | 2018-11-27 05:01:46 Socket (2) | Connecting to IP: 8.18.161.133. | 2018-11-27 05:01:46 NQZ8-CME [CBV] 5 Min #19 | Reloading chart. | 2018-11-27 05:01:46 Socket (1) | Socket gracefully closed by remote side. | 2018-11-27 05:01:46 Socket (1) | Closed. | 2018-11-27 05:01:46 Rithmic Trading | Port for executable: 54370 | 2018-11-27 05:01:46 Listening socket (1476). Port 54370 | Closed. | 2018-11-27 05:01:46 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2018-11-27 05:01:46 Created process C:\SierraChart\Rim\DTCBridge.exe. Parameters: /Port:54370. Current folder: C:\SierraChart\Rim | 2018-11-27 05:01:46 HD Request # 7 | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:46 HD Request # 7 | Sending historical data logon request message. | 2018-11-27 05:01:46 HD Request # 7 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:34. Record interval: 0. Symbol: RTYZ18 | 2018-11-27 05:01:46 + Loading additional symbol data. | 2018-11-27 05:01:47 + Loading additional symbol data. | 2018-11-27 05:01:47 HD Request # 7 | Decompressing data. | 2018-11-27 05:01:47 Socket (2) | Signaling to core to close socket | 2018-11-27 05:01:47 Socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:01:47 HD Request # 7 | Historical data for RTYZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-27 05:01:47 Historical data download thread signaled to stop. | 2018-11-27 05:01:47 HD Request # 7 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RTYZ8-CME | 2018-11-27 05:01:47 HD Request # 7 | Completion time: 1s | 2018-11-27 05:01:47 HD Request # 7 | Intraday data download complete for RTYZ8-CME. Unique request ID: 6 | 2018-11-27 05:01:47 Removed historical data download ID 6 | 2018-11-27 05:01:47 Rithmic Trading | Using primary service for historical data for RTYZ8-CME | 2018-11-27 05:01:47 Historical data service client indicated that downloads are not enabled. Symbol: RTYZ8-CME. Data Type: Intraday data | 2018-11-27 05:01:47 Historical data download ID 9 not found when removing ID from outstanding request set. | 2018-11-27 05:01:47 HD Request # 7 | Download from primary service not started due to error. | 2018-11-27 05:01:47 HD Request # 8 | Downloading Intraday chart data for ESZ8-CME to the file ESZ8-CME.scid. Service: cme | 2018-11-27 05:01:47 HD Request # 8 | Download start date-time: 2018-11-27 05:00:40.000 | 2018-11-27 05:01:47 HD Request # 8 | Using server: ds1.sierracharts.com port 10149 | 2018-11-27 05:01:47 Socket (1) | Creating socket. | 2018-11-27 05:01:47 Socket (1) | Connecting to IP: 8.18.161.135. | 2018-11-27 05:01:47 Socket (2) | Socket gracefully closed by remote side. | 2018-11-27 05:01:47 Socket (2) | Closed. | 2018-11-27 05:01:47 HD Request # 8 | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:47 HD Request # 8 | Sending historical data logon request message. | 2018-11-27 05:01:47 HD Request # 8 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:40. Record interval: 0. Symbol: ESZ18 | 2018-11-27 05:01:47 HD Request # 8 | Decompressing data. | 2018-11-27 05:01:47 Socket (1) | Signaling to core to close socket | 2018-11-27 05:01:47 HD Request # 8 | Historical data for ESZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-27 05:01:47 Socket (1) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:01:47 Historical data download thread signaled to stop. | 2018-11-27 05:01:47 HD Request # 8 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ESZ8-CME | 2018-11-27 05:01:47 HD Request # 8 | Completion time: 1s | 2018-11-27 05:01:47 HD Request # 8 | Intraday data download complete for ESZ8-CME. Unique request ID: 7 | 2018-11-27 05:01:47 Removed historical data download ID 7 | 2018-11-27 05:01:47 Rithmic Trading | Using primary service for historical data for ESZ8-CME | 2018-11-27 05:01:47 Historical data service client indicated that downloads are not enabled. Symbol: ESZ8-CME. Data Type: Intraday data | 2018-11-27 05:01:47 Historical data download ID 10 not found when removing ID from outstanding request set. | 2018-11-27 05:01:47 HD Request # 8 | Download from primary service not started due to error. | 2018-11-27 05:01:47 HD Request # 9 | Downloading Intraday chart data for YMZ8-CBOT to the file YMZ8-CBOT.scid. Service: cbot | 2018-11-27 05:01:47 HD Request # 9 | Download start date-time: 2018-11-27 05:00:40.000 | 2018-11-27 05:01:47 HD Request # 9 | Using server: ds7.sierracharts.com port 10150 | 2018-11-27 05:01:47 Socket (2) | Creating socket. | 2018-11-27 05:01:47 Socket (2) | Connecting to IP: 8.18.161.133. | 2018-11-27 05:01:47 Chart #20 has tagged chart #19 for full recalculation. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:01:47 Socket (1) | Socket gracefully closed by remote side. | 2018-11-27 05:01:47 Socket (1) | Closed. | 2018-11-27 05:01:47 HD Request # 9 | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:48 HD Request # 9 | Sending historical data logon request message. | 2018-11-27 05:01:48 HD Request # 9 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:40. Record interval: 0. Symbol: YMZ18 | 2018-11-27 05:01:48 HD Request # 9 | Decompressing data. | 2018-11-27 05:01:48 Socket (2) | Signaling to core to close socket | 2018-11-27 05:01:48 Socket (2) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:01:48 HD Request # 9 | Historical data for YMZ8-CBOT is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-11-27 05:01:48 Historical data download thread signaled to stop. | 2018-11-27 05:01:48 HD Request # 9 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for YMZ8-CBOT | 2018-11-27 05:01:48 HD Request # 9 | Completion time: 0s | 2018-11-27 05:01:48 HD Request # 9 | Intraday data download complete for YMZ8-CBOT. Unique request ID: 8 | 2018-11-27 05:01:48 Removed historical data download ID 8 | 2018-11-27 05:01:48 Rithmic Trading | Using primary service for historical data for YMZ8-CBOT | 2018-11-27 05:01:48 Historical data service client indicated that downloads are not enabled. Symbol: YMZ8-CBOT. Data Type: Intraday data | 2018-11-27 05:01:48 Historical data download ID 11 not found when removing ID from outstanding request set. | 2018-11-27 05:01:48 HD Request # 9 | Download from primary service not started due to error. | 2018-11-27 05:01:48 Socket (2) | Socket gracefully closed by remote side. | 2018-11-27 05:01:48 Socket (2) | Closed. | 2018-11-27 05:01:48 NQZ8-CME [CBV] 5 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:01:48 Chart #16 has tagged chart #8 for full recalculation. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:01:49 RTYZ8-CME [CB] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:01:49 Rithmic Trading | Bridge process is running. | 2018-11-27 05:01:49 Rithmic Trading | Connecting to the server 127.0.0.1. Port 54370 | 2018-11-27 05:01:49 DTC Client socket (1) | Creating socket. | 2018-11-27 05:01:49 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2018-11-27 05:01:49 Rithmic Trading | Connected to server. | 2018-11-27 05:01:49 Rithmic Trading | Starting socket receive thread. | 2018-11-27 05:01:49 Rithmic Trading | Sending encoding request to server: Binary VLS | 2018-11-27 05:01:49 Rithmic Trading | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:49 Rithmic Trading | Sending logon request message. | 2018-11-27 05:01:49 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2018-11-27 05:01:49 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2018-11-27 05:01:49 Rithmic Trading | Message from server: Connecting to Rithmic Topstep Trader server. | 2018-11-27 05:01:49 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2018-11-27 05:01:51 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2018-11-27 05:01:51 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2018-11-27 05:01:52 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2018-11-27 05:01:52 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2018-11-27 05:01:54 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2018-11-27 05:01:54 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2018-11-27 05:01:55 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2018-11-27 05:01:55 Rithmic Trading | Received logon response. | 2018-11-27 05:01:55 Rithmic Trading | Server Name: SC DTC Bridge. | 2018-11-27 05:01:55 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2018-11-27 05:01:55 Rithmic Trading | Successfully connected. IB='TopstepTrader', Firm='TopstepTrader'. | 2018-11-27 05:01:55 Rithmic Trading | Trading is supported. | 2018-11-27 05:01:55 Rithmic Trading | Order cancel and replace is supported. | 2018-11-27 05:01:55 Rithmic Trading | OCO Orders supported. | 2018-11-27 05:01:55 Rithmic Trading | Connected to data and trading server. | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Starting real-time market data updates for: TICKBA-NYSE. ID: 1 | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2018-11-27 05:01:55 DTC Client socket (2) | Creating socket. | 2018-11-27 05:01:55 DTC Client socket (2) | Connecting to IP: 192.81.56.146. | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Requesting security definition data for: TICKBA-NYSE. ID: 1 | 2018-11-27 05:01:55 Intraday data recording state for symbol TICKBA-NYSE is set to download 'Pending'. | 2018-11-27 05:01:55 NQZ8-CME [CBV] 5 Min #19 | Started historical data download for additional symbol TICKBA-NYSE. Download ID: 12 | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-NYSE. ID: 2 | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Requesting security definition data for: NISS-NYSE. ID: 2 | 2018-11-27 05:01:55 Intraday data recording state for symbol NISS-NYSE is set to download 'Pending'. | 2018-11-27 05:01:55 NQZ8-CME [CBV] 5 Min #19 | Started historical data download for additional symbol NISS-NYSE. Download ID: 13 | 2018-11-27 05:01:55 Delaying start of download for TICKBA-NYSE | 2018-11-27 05:01:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The YM?#-CBOT pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:55 Rithmic Trading | Starting real-time market data updates for: YMZ8-CBOT. ID: 3 | 2018-11-27 05:01:55 Rithmic Trading | Requesting security definition data for: YMZ8-CBOT. ID: 3 | 2018-11-27 05:01:55 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: YMZ8-CBOT | 2018-11-27 05:01:55 Intraday data recording state for symbol YMZ8-CBOT is set to download 'Pending'. | 2018-11-27 05:01:55 Rithmic Trading | Message from server: Received unknown message type from DTC client. Type = 603 | 2018-11-27 05:01:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The ES?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:55 Rithmic Trading | Starting real-time market data updates for: ESZ8-CME. ID: 4 | 2018-11-27 05:01:55 Rithmic Trading | Requesting security definition data for: ESZ8-CME. ID: 4 | 2018-11-27 05:01:55 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ESZ8-CME | 2018-11-27 05:01:55 Intraday data recording state for symbol ESZ8-CME is set to download 'Pending'. | 2018-11-27 05:01:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The CL?#-NYMEX pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:55 Rithmic Trading | Starting real-time market data updates for: CLF9-NYMEX. ID: 5 | 2018-11-27 05:01:55 Rithmic Trading | Requesting security definition data for: CLF9-NYMEX. ID: 5 | 2018-11-27 05:01:55 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: CLF9-NYMEX | 2018-11-27 05:01:55 Intraday data recording state for symbol CLF9-NYMEX is set to download 'Pending'. | 2018-11-27 05:01:55 'Allow Support for Sierra Chart Data Feeds' is disabled. The NQ?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:55 Rithmic Trading | Starting real-time market data updates for: NQZ8-CME. ID: 6 | 2018-11-27 05:01:55 Rithmic Trading | Requesting security definition data for: NQZ8-CME. ID: 6 | 2018-11-27 05:01:55 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQZ8-CME | 2018-11-27 05:01:55 Intraday data recording state for symbol NQZ8-CME is set to download 'Pending'. | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Connected to server. | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-11-27 05:01:55 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Sending logon request message. | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Received logon response. | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Successfully connected. | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Trading is not supported. | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-NYSE | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TICKBA-NYSE | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-TF. ID: 7 | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Requesting security definition data for: NISS-TF. ID: 7 | 2018-11-27 05:01:56 Intraday data recording state for symbol NISS-TF is set to download 'Pending'. | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Received security definition for symbol NISS-NYSE | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Received security definition for symbol TICKBA-NYSE | 2018-11-27 05:01:56 SC DTC Data with Market Depth | Received security definition for symbol NISS-TF | 2018-11-27 05:01:56 'Allow Support for Sierra Chart Data Feeds' is disabled. The RTY?#-CME pattern/symbol will not use the SC Exchange Data Feed. | 2018-11-27 05:01:56 Rithmic Trading | Starting real-time market data updates for: RTYZ8-CME. ID: 8 | 2018-11-27 05:01:56 Rithmic Trading | Requesting security definition data for: RTYZ8-CME. ID: 8 | 2018-11-27 05:01:56 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTYZ8-CME | 2018-11-27 05:01:56 Intraday data recording state for symbol RTYZ8-CME is set to download 'Pending'. | 2018-11-27 05:01:56 Requesting market depth updates for: NQZ8-CME if supported. | 2018-11-27 05:02:01 HD Request # 10 | Downloading Intraday chart data for TICKBA-NYSE to the file TICKBA-NYSE.scid. Service: statscalc | 2018-11-27 05:02:02 HD Request # 10 | Download start date-time: 2018-11-27 05:01:30.000 | 2018-11-27 05:02:02 HD Request # 10 | Using server: ds3.sierracharts.com port 10149 | 2018-11-27 05:02:02 Socket (3) | Creating socket. | 2018-11-27 05:02:02 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-11-27 05:02:02 HD Request # 10 | Setting DTC encoding to Binary VLS | 2018-11-27 05:02:02 HD Request # 10 | Sending historical data logon request message. | 2018-11-27 05:02:02 HD Request # 10 | Requesting Intraday data. Start date-time: 2018-11-27 05:01:30. Record interval: 0. Symbol: TICKBA-NYSE | 2018-11-27 05:02:02 HD Request # 10 | Decompressing data. | 2018-11-27 05:02:02 HD Request # 10 | Receiving Intraday data for TICKBA-NYSE starting at 2018-11-27 05:01:30 | 2018-11-27 05:02:02 HD Request # 10 | Timestamp of first Intraday data file record written: 2018-11-27 05:01:31 | 2018-11-27 05:02:02 Socket (3) | Signaling to core to close socket | 2018-11-27 05:02:02 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:02:02 Historical data download thread signaled to stop. | 2018-11-27 05:02:02 HD Request # 10 | Received 33 records from 2018-11-27 05:01:30 to 2018-11-27 05:02:02 (32.0 seconds) and wrote 32 records for TICKBA-NYSE | 2018-11-27 05:02:02 Added 2 Time and Sales records to Intraday data file for TICKBA-NYSE after download. | 2018-11-27 05:02:02 HD Request # 10 | Completion time: 0s | 2018-11-27 05:02:02 HD Request # 10 | Intraday data download complete for TICKBA-NYSE. Unique request ID: 12 | 2018-11-27 05:02:02 Removed historical data download ID 12 | 2018-11-27 05:02:02 Real-time Intraday chart data file updates started for TICKBA-NYSE | 2018-11-27 05:02:02 Intraday chart data file opened for TICKBA-NYSE | 2018-11-27 05:02:02 NQZ8-CME [CBV] 5 Min #19 | Historical data download for additional symbol TICKBA-NYSE with ID 12 has completed. | 2018-11-27 05:02:02 HD Request # 11 | Downloading Intraday chart data for NISS-NYSE to the file NISS-NYSE.scid. Service: statscalc | 2018-11-27 05:02:02 HD Request # 11 | Download start date-time: 2018-11-27 05:01:32.000 | 2018-11-27 05:02:02 HD Request # 11 | Using server: ds4.sierracharts.com port 10150 | 2018-11-27 05:02:02 Socket (4) | Creating socket. | 2018-11-27 05:02:02 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-11-27 05:02:02 Socket (3) | Socket gracefully closed by remote side. | 2018-11-27 05:02:02 Socket (3) | Closed. | 2018-11-27 05:02:02 HD Request # 11 | Setting DTC encoding to Binary VLS | 2018-11-27 05:02:03 HD Request # 11 | Sending historical data logon request message. | 2018-11-27 05:02:03 HD Request # 11 | Requesting Intraday data. Start date-time: 2018-11-27 05:01:32. Record interval: 0. Symbol: NISS-NYSE | 2018-11-27 05:02:03 HD Request # 11 | Decompressing data. | 2018-11-27 05:02:03 HD Request # 11 | Receiving Intraday data for NISS-NYSE starting at 2018-11-27 05:01:32 | 2018-11-27 05:02:03 HD Request # 11 | Timestamp of first Intraday data file record written: 2018-11-27 05:01:33 | 2018-11-27 05:02:03 Socket (4) | Signaling to core to close socket | 2018-11-27 05:02:03 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:02:03 Historical data download thread signaled to stop. | 2018-11-27 05:02:03 HD Request # 11 | Received 31 records from 2018-11-27 05:01:32 to 2018-11-27 05:02:02 (30.0 seconds) and wrote 30 records for NISS-NYSE | 2018-11-27 05:02:03 Added 2 Time and Sales records to Intraday data file for NISS-NYSE after download. | 2018-11-27 05:02:03 HD Request # 11 | Completion time: 0s | 2018-11-27 05:02:03 HD Request # 11 | Intraday data download complete for NISS-NYSE. Unique request ID: 13 | 2018-11-27 05:02:03 Removed historical data download ID 13 | 2018-11-27 05:02:03 Real-time Intraday chart data file updates started for NISS-NYSE | 2018-11-27 05:02:03 Intraday chart data file opened for NISS-NYSE | 2018-11-27 05:02:03 NQZ8-CME [CBV] 5 Min #19 | Historical data download for additional symbol NISS-NYSE with ID 13 has completed. | 2018-11-27 05:02:03 HD Request # 12 | Downloading Intraday chart data for YMZ8-CBOT to the file YMZ8-CBOT.scid. Service: cbot | 2018-11-27 05:02:03 HD Request # 12 | Download start date-time: 2018-11-27 05:00:40.000 | 2018-11-27 05:02:03 HD Request # 12 | Using server: ds1.sierracharts.com port 10149 | 2018-11-27 05:02:03 Socket (3) | Creating socket. | 2018-11-27 05:02:03 Socket (3) | Connecting to IP: 8.18.161.135. | 2018-11-27 05:02:03 Socket (4) | Socket gracefully closed by remote side. | 2018-11-27 05:02:03 Socket (4) | Closed. | 2018-11-27 05:02:03 HD Request # 12 | Setting DTC encoding to Binary VLS | 2018-11-27 05:02:03 HD Request # 12 | Sending historical data logon request message. | 2018-11-27 05:02:03 HD Request # 12 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:40. Record interval: 0. Symbol: YMZ18 | 2018-11-27 05:02:03 HD Request # 12 | Decompressing data. | 2018-11-27 05:02:04 HD Request # 12 | Receiving Intraday data for YMZ8-CBOT starting at 2018-11-27 05:00:40 | 2018-11-27 05:02:04 HD Request # 12 | Timestamp of first Intraday data file record written: 2018-11-27 05:00:48 | 2018-11-27 05:02:04 Socket (3) | Signaling to core to close socket | 2018-11-27 05:02:04 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:02:04 Historical data download thread signaled to stop. | 2018-11-27 05:02:04 HD Request # 12 | Received 45 records from 2018-11-27 05:00:40 to 2018-11-27 05:02:04 (84.0 seconds) and wrote 44 records for YMZ8-CBOT | 2018-11-27 05:02:04 HD Request # 12 | Completion time: 0s | 2018-11-27 05:02:04 HD Request # 12 | Intraday data download complete for YMZ8-CBOT. Unique request ID: 14 | 2018-11-27 05:02:04 Removed historical data download ID 14 | 2018-11-27 05:02:04 Real-time Intraday chart data file updates started for YMZ8-CBOT | 2018-11-27 05:02:04 Intraday chart data file opened for YMZ8-CBOT | 2018-11-27 05:02:04 Rithmic Trading | Using primary service for historical data for YMZ8-CBOT | 2018-11-27 05:02:04 Intraday data recording state for symbol YMZ8-CBOT is set to download 'Pending'. | 2018-11-27 05:02:04 HD Request # 13 | Downloading Intraday chart data for YMZ8-CBOT to the file YMZ8-CBOT.scid. Service: rithmic.trading | 2018-11-27 05:02:04 HD Request # 13 | Download start date-time: 2018-11-27 05:02:04.000 | 2018-11-27 05:02:04 HD Request # 13 | Sending historical data request. Start date-time: 2018-11-27 05:02:04. Record interval: 0. Symbol: YMZ8-CBOT | 2018-11-27 05:02:04 HD Request # 14 | Downloading Intraday chart data for ESZ8-CME to the file ESZ8-CME.scid. Service: cme | 2018-11-27 05:02:04 HD Request # 14 | Download start date-time: 2018-11-27 05:00:40.000 | 2018-11-27 05:02:04 HD Request # 14 | Using server: ds7.sierracharts.com port 10150 | 2018-11-27 05:02:04 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-11-27 05:02:04 Socket (4) | Creating socket. | 2018-11-27 05:02:04 Socket (4) | Connecting to IP: 8.18.161.133. | 2018-11-27 05:02:04 Socket (3) | Socket gracefully closed by remote side. | 2018-11-27 05:02:04 Socket (3) | Closed. | 2018-11-27 05:02:04 HD Request # 13 | Receiving Intraday data for YMZ8-CBOT starting at 2018-11-27 05:02:04 | 2018-11-27 05:02:04 HD Request # 13 | Received 1 record from 2018-11-27 05:02:04 to 2018-11-27 05:02:04 (0.0 seconds) and wrote 0 records for YMZ8-CBOT | 2018-11-27 05:02:04 HD Request # 13 | Completion time: 0s | 2018-11-27 05:02:04 HD Request # 13 | Intraday data download complete for YMZ8-CBOT. Unique request ID: 20 | 2018-11-27 05:02:04 Removed historical data download ID 20 | 2018-11-27 05:02:04 Real-time Intraday chart data file updates started for YMZ8-CBOT | 2018-11-27 05:02:04 Intraday chart data file opened for YMZ8-CBOT | 2018-11-27 05:02:04 HD Request # 14 | Setting DTC encoding to Binary VLS | 2018-11-27 05:02:04 HD Request # 14 | Sending historical data logon request message. | 2018-11-27 05:02:04 HD Request # 14 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:40. Record interval: 0. Symbol: ESZ18 | 2018-11-27 05:02:04 HD Request # 14 | Decompressing data. | 2018-11-27 05:02:04 HD Request # 14 | Receiving Intraday data for ESZ8-CME starting at 2018-11-27 05:00:40 | 2018-11-27 05:02:04 HD Request # 14 | Timestamp of first Intraday data file record written: 2018-11-27 05:00:48 | 2018-11-27 05:02:04 Socket (4) | Signaling to core to close socket | 2018-11-27 05:02:04 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:02:04 Socket (4) | Socket gracefully closed by remote side. | 2018-11-27 05:02:04 Socket (4) | Closed. | 2018-11-27 05:02:04 Opened cached Intraday file: C:\SierraChart\Data\TICKBA-NYSE.scid | 2018-11-27 05:02:05 Opened cached Intraday file: C:\SierraChart\Data\NISS-NYSE.scid | 2018-11-27 05:02:05 Historical data download thread signaled to stop. | 2018-11-27 05:02:05 HD Request # 14 | Received 198 records from 2018-11-27 05:00:40 to 2018-11-27 05:02:01 (81.0 seconds) and wrote 189 records for ESZ8-CME | 2018-11-27 05:02:05 HD Request # 14 | Completion time: 2s | 2018-11-27 05:02:05 HD Request # 14 | Intraday data download complete for ESZ8-CME. Unique request ID: 15 | 2018-11-27 05:02:05 Removed historical data download ID 15 | 2018-11-27 05:02:05 Real-time Intraday chart data file updates started for ESZ8-CME | 2018-11-27 05:02:05 Intraday chart data file opened for ESZ8-CME | 2018-11-27 05:02:05 Rithmic Trading | Using primary service for historical data for ESZ8-CME | 2018-11-27 05:02:05 Intraday data recording state for symbol ESZ8-CME is set to download 'Pending'. | 2018-11-27 05:02:05 HD Request # 15 | Downloading Intraday chart data for ESZ8-CME to the file ESZ8-CME.scid. Service: rithmic.trading | 2018-11-27 05:02:05 HD Request # 15 | Download start date-time: 2018-11-27 05:02:01.000 | 2018-11-27 05:02:05 HD Request # 15 | Sending historical data request. Start date-time: 2018-11-27 05:02:01. Record interval: 0. Symbol: ESZ8-CME | 2018-11-27 05:02:05 HD Request # 16 | Downloading Intraday chart data for CLF9-NYMEX to the file CLF9-NYMEX.scid. Service: nymex | 2018-11-27 05:02:05 HD Request # 16 | Download start date-time: 2018-11-27 05:00:46.000 | 2018-11-27 05:02:05 HD Request # 16 | Using server: ds1.sierracharts.com port 10149 | 2018-11-27 05:02:05 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-11-27 05:02:05 Socket (3) | Creating socket. | 2018-11-27 05:02:05 Socket (3) | Connecting to IP: 8.18.161.135. | 2018-11-27 05:02:05 NQZ8-CME [CBV] 5 Min #19 | Reloading chart. | 2018-11-27 05:02:05 Chart #16 has tagged chart #8 for full recalculation. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:02:05 Chart #20 has tagged chart #19 for full recalculation. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:02:05 HD Request # 16 | Setting DTC encoding to Binary VLS | 2018-11-27 05:02:05 HD Request # 16 | Sending historical data logon request message. | 2018-11-27 05:02:05 + Loading additional symbol data. | 2018-11-27 05:02:05 + Loading additional symbol data. | 2018-11-27 05:02:05 HD Request # 15 | Receiving Intraday data for ESZ8-CME starting at 2018-11-27 05:02:01 | 2018-11-27 05:02:05 HD Request # 15 | Timestamp of first Intraday data file record written: 2018-11-27 05:02:06 | 2018-11-27 05:02:05 HD Request # 15 | Received 18 records from 2018-11-27 05:02:01 to 2018-11-27 05:02:06 (5.0 seconds) and wrote 5 records for ESZ8-CME | 2018-11-27 05:02:05 HD Request # 15 | Completion time: 0s | 2018-11-27 05:02:05 HD Request # 15 | Intraday data download complete for ESZ8-CME. Unique request ID: 21 | 2018-11-27 05:02:05 Removed historical data download ID 21 | 2018-11-27 05:02:05 Real-time Intraday chart data file updates started for ESZ8-CME | 2018-11-27 05:02:05 Intraday chart data file opened for ESZ8-CME | 2018-11-27 05:02:05 HD Request # 16 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:46. Record interval: 0. Symbol: CLF19 | 2018-11-27 05:02:05 HD Request # 16 | Decompressing data. | 2018-11-27 05:02:06 HD Request # 16 | Receiving Intraday data for CLF9-NYMEX starting at 2018-11-27 05:00:46 | 2018-11-27 05:02:06 HD Request # 16 | Timestamp of first Intraday data file record written: 2018-11-27 05:00:56 | 2018-11-27 05:02:06 Socket (3) | Signaling to core to close socket | 2018-11-27 05:02:06 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:02:06 Historical data download thread signaled to stop. | 2018-11-27 05:02:06 HD Request # 16 | Received 183 records from 2018-11-27 05:00:46 to 2018-11-27 05:02:04 (78.0 seconds) and wrote 174 records for CLF9-NYMEX | 2018-11-27 05:02:06 HD Request # 16 | Completion time: 0s | 2018-11-27 05:02:06 HD Request # 16 | Intraday data download complete for CLF9-NYMEX. Unique request ID: 16 | 2018-11-27 05:02:06 Removed historical data download ID 16 | 2018-11-27 05:02:06 Real-time Intraday chart data file updates started for CLF9-NYMEX | 2018-11-27 05:02:06 Intraday chart data file opened for CLF9-NYMEX | 2018-11-27 05:02:06 Rithmic Trading | Using primary service for historical data for CLF9-NYMEX | 2018-11-27 05:02:06 Intraday data recording state for symbol CLF9-NYMEX is set to download 'Pending'. | 2018-11-27 05:02:06 HD Request # 17 | Downloading Intraday chart data for CLF9-NYMEX to the file CLF9-NYMEX.scid. Service: rithmic.trading | 2018-11-27 05:02:06 HD Request # 17 | Download start date-time: 2018-11-27 05:02:04.000 | 2018-11-27 05:02:06 HD Request # 17 | Sending historical data request. Start date-time: 2018-11-27 05:02:04. Record interval: 0. Symbol: CLF9-NYMEX | 2018-11-27 05:02:06 HD Request # 18 | Downloading Intraday chart data for NQZ8-CME to the file NQZ8-CME.scid. Service: cme | 2018-11-27 05:02:06 HD Request # 18 | Download start date-time: 2018-11-27 05:00:46.000 | 2018-11-27 05:02:06 HD Request # 18 | Using server: ds7.sierracharts.com port 10150 | 2018-11-27 05:02:06 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-11-27 05:02:06 Socket (4) | Creating socket. | 2018-11-27 05:02:06 Socket (4) | Connecting to IP: 8.18.161.133. | 2018-11-27 05:02:06 Socket (3) | Socket gracefully closed by remote side. | 2018-11-27 05:02:06 Socket (3) | Closed. | 2018-11-27 05:02:06 HD Request # 18 | Setting DTC encoding to Binary VLS | 2018-11-27 05:02:06 HD Request # 18 | Sending historical data logon request message. | 2018-11-27 05:02:06 HD Request # 17 | Receiving Intraday data for CLF9-NYMEX starting at 2018-11-27 05:02:04 | 2018-11-27 05:02:06 HD Request # 17 | Timestamp of first Intraday data file record written: 2018-11-27 05:02:07 | 2018-11-27 05:02:06 HD Request # 17 | Received 20 records from 2018-11-27 05:02:04 to 2018-11-27 05:02:07 (3.0 seconds) and wrote 3 records for CLF9-NYMEX | 2018-11-27 05:02:06 HD Request # 17 | Completion time: 0s | 2018-11-27 05:02:06 HD Request # 17 | Intraday data download complete for CLF9-NYMEX. Unique request ID: 22 | 2018-11-27 05:02:06 Removed historical data download ID 22 | 2018-11-27 05:02:06 Real-time Intraday chart data file updates started for CLF9-NYMEX | 2018-11-27 05:02:06 Intraday chart data file opened for CLF9-NYMEX | 2018-11-27 05:02:06 HD Request # 18 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:46. Record interval: 0. Symbol: NQZ18 | 2018-11-27 05:02:06 HD Request # 18 | Decompressing data. | 2018-11-27 05:02:06 HD Request # 18 | Receiving Intraday data for NQZ8-CME starting at 2018-11-27 05:00:46 | 2018-11-27 05:02:06 HD Request # 18 | Timestamp of first Intraday data file record written: 2018-11-27 05:00:48 | 2018-11-27 05:02:06 Socket (4) | Signaling to core to close socket | 2018-11-27 05:02:06 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:02:06 Historical data download thread signaled to stop. | 2018-11-27 05:02:06 HD Request # 18 | Received 101 records from 2018-11-27 05:00:46 to 2018-11-27 05:02:06 (80.0 seconds) and wrote 100 records for NQZ8-CME | 2018-11-27 05:02:06 HD Request # 18 | Completion time: 0s | 2018-11-27 05:02:06 HD Request # 18 | Intraday data download complete for NQZ8-CME. Unique request ID: 17 | 2018-11-27 05:02:06 Removed historical data download ID 17 | 2018-11-27 05:02:06 Real-time Intraday chart data file updates started for NQZ8-CME | 2018-11-27 05:02:06 Intraday chart data file opened for NQZ8-CME | 2018-11-27 05:02:06 Rithmic Trading | Using primary service for historical data for NQZ8-CME | 2018-11-27 05:02:06 Intraday data recording state for symbol NQZ8-CME is set to download 'Pending'. | 2018-11-27 05:02:06 HD Request # 19 | Downloading Intraday chart data for NQZ8-CME to the file NQZ8-CME.scid. Service: rithmic.trading | 2018-11-27 05:02:06 HD Request # 19 | Download start date-time: 2018-11-27 05:02:06.000 | 2018-11-27 05:02:06 HD Request # 19 | Sending historical data request. Start date-time: 2018-11-27 05:02:06. Record interval: 0. Symbol: NQZ8-CME | 2018-11-27 05:02:06 HD Request # 20 | Downloading Intraday chart data for NISS-TF to the file NISS-TF.scid. Service: statscalc | 2018-11-27 05:02:06 HD Request # 20 | Download start date-time: 2018-11-27 05:01:42.000 | 2018-11-27 05:02:06 HD Request # 20 | Using server: ds3.sierracharts.com port 10149 | 2018-11-27 05:02:06 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-11-27 05:02:06 Socket (3) | Creating socket. | 2018-11-27 05:02:06 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-11-27 05:02:06 Socket (4) | Socket gracefully closed by remote side. | 2018-11-27 05:02:06 Socket (4) | Closed. | 2018-11-27 05:02:06 HD Request # 19 | Receiving Intraday data for NQZ8-CME starting at 2018-11-27 05:02:06 | 2018-11-27 05:02:07 HD Request # 19 | Received 6 records from 2018-11-27 05:02:06 to 2018-11-27 05:02:06 (0.0 seconds) and wrote 0 records for NQZ8-CME | 2018-11-27 05:02:07 HD Request # 19 | Completion time: 0s | 2018-11-27 05:02:07 HD Request # 19 | Intraday data download complete for NQZ8-CME. Unique request ID: 23 | 2018-11-27 05:02:07 Removed historical data download ID 23 | 2018-11-27 05:02:07 Real-time Intraday chart data file updates started for NQZ8-CME | 2018-11-27 05:02:07 Intraday chart data file opened for NQZ8-CME | 2018-11-27 05:02:07 HD Request # 20 | Setting DTC encoding to Binary VLS | 2018-11-27 05:02:07 HD Request # 20 | Sending historical data logon request message. | 2018-11-27 05:02:07 HD Request # 20 | Requesting Intraday data. Start date-time: 2018-11-27 05:01:42. Record interval: 0. Symbol: NISS-TF | 2018-11-27 05:02:07 HD Request # 20 | Decompressing data. | 2018-11-27 05:02:07 HD Request # 20 | Receiving Intraday data for NISS-TF starting at 2018-11-27 05:01:42 | 2018-11-27 05:02:07 HD Request # 20 | Timestamp of first Intraday data file record written: 2018-11-27 05:01:43 | 2018-11-27 05:02:07 Socket (3) | Signaling to core to close socket | 2018-11-27 05:02:07 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:02:07 Historical data download thread signaled to stop. | 2018-11-27 05:02:07 HD Request # 20 | Received 25 records from 2018-11-27 05:01:42 to 2018-11-27 05:02:06 (24.0 seconds) and wrote 24 records for NISS-TF | 2018-11-27 05:02:07 Added 1 Time and Sales records to Intraday data file for NISS-TF after download. | 2018-11-27 05:02:07 HD Request # 20 | Completion time: 0s | 2018-11-27 05:02:07 HD Request # 20 | Intraday data download complete for NISS-TF. Unique request ID: 18 | 2018-11-27 05:02:07 Removed historical data download ID 18 | 2018-11-27 05:02:07 Real-time Intraday chart data file updates started for NISS-TF | 2018-11-27 05:02:07 Intraday chart data file opened for NISS-TF | 2018-11-27 05:02:07 HD Request # 21 | Downloading Intraday chart data for RTYZ8-CME to the file RTYZ8-CME.scid. Service: cme | 2018-11-27 05:02:07 HD Request # 21 | Download start date-time: 2018-11-27 05:00:34.000 | 2018-11-27 05:02:07 HD Request # 21 | Using server: ds1.sierracharts.com port 10150 | 2018-11-27 05:02:07 Socket (4) | Creating socket. | 2018-11-27 05:02:07 Socket (4) | Connecting to IP: 8.18.161.135. | 2018-11-27 05:02:07 Socket (3) | Socket gracefully closed by remote side. | 2018-11-27 05:02:07 Socket (3) | Closed. | 2018-11-27 05:02:07 RTYZ8-CME [CB] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:02:07 HD Request # 21 | Setting DTC encoding to Binary VLS | 2018-11-27 05:02:07 HD Request # 21 | Sending historical data logon request message. | 2018-11-27 05:02:07 HD Request # 21 | Requesting Intraday data. Start date-time: 2018-11-27 05:00:34. Record interval: 0. Symbol: RTYZ18 | 2018-11-27 05:02:07 Opened cached Intraday file: C:\SierraChart\Data\YMZ8-CBOT.scid | 2018-11-27 05:02:08 Opened cached Intraday file: C:\SierraChart\Data\CLF9-NYMEX.scid | 2018-11-27 05:02:08 Opened cached Intraday file: C:\SierraChart\Data\NISS-TF.scid | 2018-11-27 05:02:08 HD Request # 21 | Decompressing data. | 2018-11-27 05:02:08 HD Request # 21 | Receiving Intraday data for RTYZ8-CME starting at 2018-11-27 05:00:34 | 2018-11-27 05:02:08 HD Request # 21 | Timestamp of first Intraday data file record written: 2018-11-27 05:00:47 | 2018-11-27 05:02:08 Socket (4) | Signaling to core to close socket | 2018-11-27 05:02:08 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-11-27 05:02:08 Historical data download thread signaled to stop. | 2018-11-27 05:02:08 HD Request # 21 | Received 15 records from 2018-11-27 05:00:34 to 2018-11-27 05:01:56 (82.0 seconds) and wrote 14 records for RTYZ8-CME | 2018-11-27 05:02:08 HD Request # 21 | Completion time: 0s | 2018-11-27 05:02:08 HD Request # 21 | Intraday data download complete for RTYZ8-CME. Unique request ID: 19 | 2018-11-27 05:02:08 Removed historical data download ID 19 | 2018-11-27 05:02:08 Real-time Intraday chart data file updates started for RTYZ8-CME | 2018-11-27 05:02:08 Intraday chart data file opened for RTYZ8-CME | 2018-11-27 05:02:08 Rithmic Trading | Using primary service for historical data for RTYZ8-CME | 2018-11-27 05:02:08 Intraday data recording state for symbol RTYZ8-CME is set to download 'Pending'. | 2018-11-27 05:02:08 HD Request # 22 | Downloading Intraday chart data for RTYZ8-CME to the file RTYZ8-CME.scid. Service: rithmic.trading | 2018-11-27 05:02:08 HD Request # 22 | Download start date-time: 2018-11-27 05:01:56.000 | 2018-11-27 05:02:08 HD Request # 22 | Sending historical data request. Start date-time: 2018-11-27 05:01:56. Record interval: 0. Symbol: RTYZ8-CME | 2018-11-27 05:02:08 Rithmic Trading | Message from server: Requesting historical Tick data. | 2018-11-27 05:02:08 Chart #20 has tagged chart #19 for full recalculation. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:02:08 Socket (4) | Socket gracefully closed by remote side. | 2018-11-27 05:02:08 Socket (4) | Closed. | 2018-11-27 05:02:08 HD Request # 22 | Receiving Intraday data for RTYZ8-CME starting at 2018-11-27 05:01:56 | 2018-11-27 05:02:08 HD Request # 22 | Received 1 record from 2018-11-27 05:01:56 to 2018-11-27 05:01:56 (0.0 seconds) and wrote 0 records for RTYZ8-CME | 2018-11-27 05:02:08 HD Request # 22 | Completion time: 0s | 2018-11-27 05:02:08 HD Request # 22 | Intraday data download complete for RTYZ8-CME. Unique request ID: 24 | 2018-11-27 05:02:08 Removed historical data download ID 24 | 2018-11-27 05:02:08 Real-time Intraday chart data file updates started for RTYZ8-CME | 2018-11-27 05:02:08 Intraday chart data file opened for RTYZ8-CME | 2018-11-27 05:02:08 NQZ8-CME [CBV] 5 Min #19 | Performing a full recalculation because it has been tagged. Chartbook: 2018-10-24_Complete.cht | 2018-11-27 05:02:08 Opened cached Intraday file: C:\SierraChart\Data\NQZ8-CME.scid | 2018-11-27 05:02:11 Opened cached Intraday file: C:\SierraChart\Data\RTYZ8-CME.scid | 2018-11-27 05:02:11 Opened cached Intraday file: C:\SierraChart\Data\ESZ8-CME.scid | 2018-11-27 05:02:14 Date Time Of Last Edit: 2018-11-27 10:04:18
[2019-07-07 14:00:01] |
Cavalry3162 - Posts: 523 |
SC, anything?
[2019-07-10 04:51:30] |
We are testing the Chartbook now to see what GDI count we see.
[2019-07-10 17:57:36] |
We are working on the issue of the high GDI count.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-10 17:57:54
[2019-07-10 18:17:38] |
that sounds great.. however, GPU load isnt exactly high.. could the gdi count still slow things down even though the gpu has plenty of room? thanks, Andreas |
[2019-07-10 22:57:45] |
The GDI count is just too high. Windows is not handling this well. If it is over 500, this is not good and yours is over 1000.
[2019-07-14 03:59:30] |
In the next release there is going to be a reduction of the GDI count, but we have discovered another reason for the high GDI object count. The reason has to do with all of your detached charts have their own control bar and some of those control bar items use graphics rather than text and each of those graphics is a separate bitmap object. If you disable the control bars on the detached charts and find you have a significantly reduced GDI count and then improved performance, then this really proves just how totally and completely abysmal and poorly designed the Windows operating system is in regards to GDI objects. This is beyond comprehension that having a significant number of bitmaps allocated is causing such a problem. It should cause zero performance impact. There really is no other way to say this than the Microsoft engineers who worked on this are complete dummies. And the fact that they have not even taken care of this to this day is shocking. Please do let us know if removing the control bars from detached charts improves performance significantly. If so we will then add this to our list of items which can cause high CPU usage. And it is the buttons which use graphics which is the problem. If a Control Bar button is just plaintext it is not a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-14 04:30:28
[2019-07-14 08:19:13] |
SC, thank you for taking the time and discover this. i obviously do not have a performance impact yet but disabling like 10 control bars (all i had in my current chartbook) certainly decreased the number of gdi objects by almost 30% from 1041+268 to 780+182 (i have 1 main SC and 1 instance running, in an attempt to increase performance, which didnt actually work out) i will report on monday how this is behaving in real life and if there's any improvement. i am also looking forward to your next release to see if there's an additional reduction in gdi objects as well as a noticable improvement performance wise. i have attached my latest 2 chartbooks (1 for each instance i am running) just in case.. Andreas Date Time Of Last Edit: 2019-07-14 08:38:59
Private File Private File SC_GDI_after.png / V - Attached On 2019-07-14 08:19:05 UTC - Size: 21.79 KB - 318 views |
[2019-07-15 07:26:51] |
We are releasing 1949 in about 15 minutes. We would expect this is going to help along with removing those control bars. Really you just need to remove the images from the control bar buttons and just have plaintext for the buttons. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-15 13:44:21] |
that latest version certainly helped a lot.. first of all gdi count is down drastically and seems to be way more dynamic than in prev releases.. so it looks like you guys kinda release uneeded graphics objects now. 2nd of all, performance wise its MUCH better than before. so i have at least some "near real time" charts again now, while they were like 5sec snapshots before. thanks a lot and great job! |
SC_GDI_new.png / V - Attached On 2019-07-15 13:43:57 UTC - Size: 6.67 KB - 326 views |
[2019-07-15 14:57:08] |
This is good to know.
[2021-05-10 15:54:19] |
jwick - Posts: 142 |
Hi! I am experiencing the same scenario as the OP (7 monitors, very low cpu / gpu usage (disconnected from data feed with no charts loading / calculating) but opening any window (eg: chart settings) takes a long time). Does the GDI count per instance matter or does the total GDI count matter? My GDI count is around 300 per instance but I have 8 instances opened. Would the 2400 total GDI count across all instances contribute to the behavior within a single instance?
[2021-05-11 16:34:09] |
That GDI count per instance, is low and not an issue at all. Refer to help topic 30 for further help with performance issues: https://www.sierrachart.com/index.php?l=helpdetails30.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
