Date/Time: Mon, 06 May 2024 11:30:16 +0000
[Programming Help] - Problem is - background hides candles
View Count: 865
[2018-11-26 13:09:13] |
User517260 - Posts: 97 |
I use in one study a few subgraphs: SCSubgraphRef ID2_Background_Sub = sc.Subgraph[3]; SCSubgraphRef ID17_BuyCandle_Sub = sc.Subgraph[19]; SCSubgraphRef ID16_SellCandle_Sub = sc.Subgraph[20]; ID2_Background_Sub.Name = "ID2: Background"; ID2_Background_Sub.DrawStyle = DRAWSTYLE_BACKGROUND_TRANSPARENT; ID2_Background_Sub.PrimaryColor = RGB(64,64,64); ID2_Background_Sub.DrawZeros = false; ID2_Background_Sub.DisplayNameValueInWindowsFlags = 0; ID17_BuyCandle_Sub.Name = "ID17: BUY CANDLE"; ID17_BuyCandle_Sub.DrawStyle = DRAWSTYLE_COLOR_BAR_CANDLE_FILL; ID17_BuyCandle_Sub.PrimaryColor = RGB(0, 157, 0); ID17_BuyCandle_Sub.DrawZeros = false; ID16_SellCandle_Sub.Name = "ID16: SELL CANDLE"; ID16_SellCandle_Sub.DrawStyle = DRAWSTYLE_COLOR_BAR_CANDLE_FILL; ID16_SellCandle_Sub.PrimaryColor = RGB(64, 0, 64); ID16_SellCandle_Sub.DrawZeros = false; Problem is - background hides candles. If I use DRAWSTYLE_IGNORE for backgronud - I see normal colored candles, but I can't see background and colored candles same time - it is a problem, because I need to have only one study which draws background depend of time and colored candles. What I have to do to decide this problem? Thanks! |
[2018-11-26 21:05:35] |
Refer to the following ACSIL variable: ACSIL Interface Members - Variables and Arrays: sc.DrawStudyUnderneathMainPriceGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-26 22:52:06] |
I have following code in source cpp file: sc.GraphName = "Custom Indicator"; sc.AutoLoop = 1; sc.GraphRegion = 0; sc.DrawZeros = false; sc.DrawStudyUnderneathMainPriceGraph = 1; You may see on video https://youtu.be/C6rl-NyKJfs it does not matter value of sc.DrawStudyUnderneathMainPriceGraph. Green candles are drawing by my study, same study draws gray background. But as soon as I switch on background - all green bars become invisible - only red and blue bars as default colors of candles. I don't know what to do do see same time background and colored green candles. Please help me! Date Time Of Last Edit: 2018-11-26 22:55:39
[2018-12-04 08:58:59] |
Dear support, I didn't get reply from your side since 26 Nov 2018. Please reply me as soon as possible.
[2018-12-04 09:42:53] |
You really need to use separate studies for coloring the bars and coloring the background because when a study is drawing a background , it is going to be drawn underneath the price bars. So if you are trying to color the bars also within the same study, that is a problem and you will not see the coloring.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-04 09:43:25
[2018-12-04 09:53:25] |
Ok, now it is clear, thanks for reply!
