Date/Time: Sat, 15 Aug 2026 00:41:21 +0000
data connection problem foe Joe Trainor
View Count: 1848
[2013-11-05 00:39:10]
User37941 - Posts: 10
Software version: 1040 | 2013-11-04 15:03:32
Usage end date: 2013-11-15 | 2013-11-04 15:03:32
Enabled for: Sierra Chart Historical Data Service. | 2013-11-04 15:03:32
Active service: Zen-Fire | 2013-11-04 15:03:32
Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2013-11-04 15:03:32
2013-11-04 15:03:32 Local computer clock time | 2013-11-04 15:03:32
2013-11-04 23:03:32 GMT time | 2013-11-04 15:03:32
2013-11-04 15:03:32 Time zone adjusted time | 2013-11-04 15:03:32
Time difference to server time: 0 seconds. | 2013-11-04 15:03:32
Program path: C:\SierraChart\ | 2013-11-04 15:03:32
Data Files path: C:\SierraChart\Data\ | 2013-11-04 15:03:32
OS Version Number: 6.1 | 2013-11-04 15:03:32
Rithmic 01 - Port for executable: 27844 | 2013-11-04 15:03:37
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:03:37
Rithmic 01: Connecting to the server 127.0.0.1. Port 27844 | 2013-11-04 15:03:38
The network socket is connected. | 2013-11-04 15:03:38
Rithmic 01: Connected to server. | 2013-11-04 15:03:38
Rithmic 01: Sending logon request message. | 2013-11-04 15:03:38
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:03:38
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:03:38
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:03:38
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:03:39
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:03:40
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:03:40
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:03:40
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:03:40
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:03:40
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:03:40
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:03:40
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:03:40
Rithmic 01 - Port for executable: 30660 | 2013-11-04 15:03:41
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:03:41
Rithmic 01: Connecting to the server 127.0.0.1. Port 30660 | 2013-11-04 15:03:42
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:03:43
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:03:43
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:03:43
Rithmic 01: Disconnected from the server. | 2013-11-04 15:03:43
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:03:43
Rithmic 01 - Port for executable: 31172 | 2013-11-04 15:03:44
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:03:44
Rithmic 01: Connecting to the server 127.0.0.1. Port 31172 | 2013-11-04 15:03:45
The network socket is connected. | 2013-11-04 15:03:45
Rithmic 01: Connected to server. | 2013-11-04 15:03:45
Rithmic 01: Sending logon request message. | 2013-11-04 15:03:45
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:03:45
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:03:45
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:03:45
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:03:46
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:03:47
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:03:47
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:03:47
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:03:47
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:03:47
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:03:47
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:03:47
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:03:47
Rithmic 01 - Port for executable: 34244 | 2013-11-04 15:03:48
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:03:48
Rithmic 01: Connecting to the server 127.0.0.1. Port 34244 | 2013-11-04 15:03:49
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:03:50
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:03:50
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:03:50
Rithmic 01: Disconnected from the server. | 2013-11-04 15:03:50
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:03:50
Rithmic 01 - Port for executable: 34756 | 2013-11-04 15:03:51
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:03:51
Rithmic 01: Connecting to the server 127.0.0.1. Port 34756 | 2013-11-04 15:03:52
The network socket is connected. | 2013-11-04 15:03:52
Rithmic 01: Connected to server. | 2013-11-04 15:03:52
Rithmic 01: Sending logon request message. | 2013-11-04 15:03:52
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:03:52
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:03:52
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:03:52
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:03:53
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:03:54
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:03:54
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:03:54
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:03:54
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:03:54
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:03:54
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:03:54
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:03:54
Rithmic 01 - Port for executable: 37572 | 2013-11-04 15:03:55
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:03:55
Rithmic 01: Connecting to the server 127.0.0.1. Port 37572 | 2013-11-04 15:03:56
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:03:57
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:03:57
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:03:57
Rithmic 01: Disconnected from the server. | 2013-11-04 15:03:57
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:03:57
Rithmic 01 - Port for executable: 38084 | 2013-11-04 15:03:58
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:03:58
Rithmic 01: Connecting to the server 127.0.0.1. Port 38084 | 2013-11-04 15:03:59
The network socket is connected. | 2013-11-04 15:03:59
Rithmic 01: Connected to server. | 2013-11-04 15:03:59
Rithmic 01: Sending logon request message. | 2013-11-04 15:03:59
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:03:59
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:03:59
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:03:59
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:04:00
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:04:01
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:04:01
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:04:01
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:04:01
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:01
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:01
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:04:01
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:01
Rithmic 01 - Port for executable: 41156 | 2013-11-04 15:04:02
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:02
Rithmic 01: Connecting to the server 127.0.0.1. Port 41156 | 2013-11-04 15:04:03
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:04:04
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:04
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:04
Rithmic 01: Disconnected from the server. | 2013-11-04 15:04:04
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:04
Rithmic 01 - Port for executable: 41924 | 2013-11-04 15:04:05
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:05
Rithmic 01: Connecting to the server 127.0.0.1. Port 41924 | 2013-11-04 15:04:06
The network socket is connected. | 2013-11-04 15:04:06
Rithmic 01: Connected to server. | 2013-11-04 15:04:06
Rithmic 01: Sending logon request message. | 2013-11-04 15:04:06
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:04:06
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:04:06
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:04:06
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:04:07
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:04:08
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:04:08
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:04:08
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:04:08
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:08
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:08
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:04:08
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:08
Rithmic 01 - Port for executable: 46276 | 2013-11-04 15:04:09
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:09
Rithmic 01: Connecting to the server 127.0.0.1. Port 46276 | 2013-11-04 15:04:10
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:04:11
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:11
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:11
Rithmic 01: Disconnected from the server. | 2013-11-04 15:04:11
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:11
Rithmic 01 - Port for executable: 46788 | 2013-11-04 15:04:12
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:12
Rithmic 01: Connecting to the server 127.0.0.1. Port 46788 | 2013-11-04 15:04:13
The network socket is connected. | 2013-11-04 15:04:13
Rithmic 01: Connected to server. | 2013-11-04 15:04:13
Rithmic 01: Sending logon request message. | 2013-11-04 15:04:13
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:04:13
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:04:13
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:04:13
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:04:14
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:04:14
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:04:14
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:04:14
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:04:14
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:15
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:15
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:04:15
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:15
Rithmic 01 - Port for executable: 49604 | 2013-11-04 15:04:16
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:16
Rithmic 01: Connecting to the server 127.0.0.1. Port 49604 | 2013-11-04 15:04:17
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:04:18
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:18
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:18
Rithmic 01: Disconnected from the server. | 2013-11-04 15:04:18
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:18
Rithmic 01 - Port for executable: 50116 | 2013-11-04 15:04:19
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:19
Rithmic 01: Connecting to the server 127.0.0.1. Port 50116 | 2013-11-04 15:04:20
The network socket is connected. | 2013-11-04 15:04:20
Rithmic 01: Connected to server. | 2013-11-04 15:04:20
Rithmic 01: Sending logon request message. | 2013-11-04 15:04:20
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:04:20
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:04:20
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:04:20
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:04:21
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:04:21
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:04:21
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:04:21
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:04:21
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:21
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:21
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:04:22
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:22
Rithmic 01 - Port for executable: 52932 | 2013-11-04 15:04:23
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:23
Rithmic 01: Connecting to the server 127.0.0.1. Port 52932 | 2013-11-04 15:04:24
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:04:25
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:25
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:25
Rithmic 01: Disconnected from the server. | 2013-11-04 15:04:25
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:25
Rithmic 01 - Port for executable: 53444 | 2013-11-04 15:04:26
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:26
Rithmic 01: Connecting to the server 127.0.0.1. Port 53444 | 2013-11-04 15:04:27
The network socket is connected. | 2013-11-04 15:04:27
Rithmic 01: Connected to server. | 2013-11-04 15:04:27
Rithmic 01: Sending logon request message. | 2013-11-04 15:04:27
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:04:27
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:04:27
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:04:27
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:04:28
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:04:28
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:04:28
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:04:28
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:04:28
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:28
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:28
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:04:29
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:29
Rithmic 01 - Port for executable: 56260 | 2013-11-04 15:04:30
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:30
Rithmic 01: Connecting to the server 127.0.0.1. Port 56260 | 2013-11-04 15:04:31
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:04:32
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:32
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:32
Rithmic 01: Disconnected from the server. | 2013-11-04 15:04:32
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:32
Rithmic 01 - Port for executable: 56772 | 2013-11-04 15:04:33
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:33
Rithmic 01: Connecting to the server 127.0.0.1. Port 56772 | 2013-11-04 15:04:34
The network socket is connected. | 2013-11-04 15:04:34
Rithmic 01: Connected to server. | 2013-11-04 15:04:34
Rithmic 01: Sending logon request message. | 2013-11-04 15:04:34
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:04:34
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:04:34
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:04:34
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:04:35
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:04:35
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:04:35
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:04:35
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:04:35
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:35
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:35
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:04:35
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:35
Rithmic 01 - Port for executable: 59588 | 2013-11-04 15:04:36
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:36
Rithmic 01: Connecting to the server 127.0.0.1. Port 59588 | 2013-11-04 15:04:38
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:04:39
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:39
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:39
Rithmic 01: Disconnected from the server. | 2013-11-04 15:04:39
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:39
Rithmic 01 - Port for executable: 60100 | 2013-11-04 15:04:40
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:40
Rithmic 01: Connecting to the server 127.0.0.1. Port 60100 | 2013-11-04 15:04:41
The network socket is connected. | 2013-11-04 15:04:41
Rithmic 01: Connected to server. | 2013-11-04 15:04:41
Rithmic 01: Sending logon request message. | 2013-11-04 15:04:41
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:04:41
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:04:41
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:04:41
Rithmic 01 - Alert Message: Market Data Connection Opened. | 2013-11-04 15:04:42
Rithmic 01 - Alert Message: Market Data Connection Login Failed. permission denied | 2013-11-04 15:04:42
Zen-Fire GSP Server Info - Server Name: Sierra Chart GSP Bridge. Server Version: 1.1. Provider Name: Zen-Fire GSP. | 2013-11-04 15:04:42
Zen-Fire GSP - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2013-11-04 15:04:42
Zen-Fire GSP - Logon error from server: | 2013-11-04 15:04:42
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:42
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:42
Zen-Fire GSP: Disconnected from the server. | 2013-11-04 15:04:42
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:42
Rithmic 01 - Port for executable: 62916 | 2013-11-04 15:04:44
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:44
Rithmic 01: Connecting to the server 127.0.0.1. Port 62916 | 2013-11-04 15:04:45
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-04 15:04:46
Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-11-04 15:04:46
To prevent further connection attempts, select File >> Disconnect. | 2013-11-04 15:04:46
Rithmic 01: Disconnected from the server. | 2013-11-04 15:04:46
Will reconnect to the server in 1.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-11-04 15:04:46
Rithmic 01 - Port for executable: 63428 | 2013-11-04 15:04:47
Rithmic 01 - Starting server: C:\SierraChart\Rim\GSPBridge.exe | 2013-11-04 15:04:47
Rithmic 01: Connecting to the server 127.0.0.1. Port 63428 | 2013-11-04 15:04:48
The network socket is connected. | 2013-11-04 15:04:48
Rithmic 01: Connected to server. | 2013-11-04 15:04:48
Rithmic 01: Sending logon request message. | 2013-11-04 15:04:48
Rithmic 01 - Starting the connection process to data and trading service. | 2013-11-04 15:04:48
Rithmic 01 - Logging is enabled. Log file: Rithmic.log | 2013-11-04 15:04:48
Rithmic 01 - Connecting to Zen-Fire server. | 2013-11-04 15:04:48
File >> Disconnect selected. | 2013-11-04 15:04:48
Rithmic 01: Disconnected from the server. | 2013-11-04 15:04:48
[2013-11-05 00:56:03]
You have received a Permission Denied error:
If this is a Zen-Fire demo account, there is not likely a whole lot that can be done. It is a Live account, please contact your broker about this.
Do you have a Live funded account yet?
[2013-11-05 14:29:55]
Yes, this is a Zen Fire demo account so no funding yet. Why would funding make a difference?
Thanks...
[2013-11-05 15:34:36]
Rithmic or Zen-Fire demo accounts apparently never are able to connect. We do not control those. A Live account you should be able to connect with.
