Date/Time: Fri, 03 May 2024 03:31:15 +0000
Moving stop and take profit after running Send Attached Orders
View Count: 1484
[2018-11-22 11:37:40] |
samual sprat - Posts: 343 |
Hi, When I use Send Attached Orders (by price or position) and I try to use keyboard shortcuts Target Order Tick Up/Target Order Tick Down/Stop Order Tick Up/Stop Order Tick Down to move the SL and TP, the keyboard shortcuts don't work. Also I'm using Trade Management By Study to trail the stop loss with but it doesn't work after using Send Attached Orders Thanks S Date Time Of Last Edit: 2018-11-22 13:28:49
[2018-11-24 21:52:03] |
We will add support for this.
[2018-11-25 03:55:17] |
We will add support for the keyboard shortcuts but not for the Trade Management by Study. That was designed to work with Attached Orders only. When you are sending Attached Orders after the parent order they are not considered Attached Orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-25 05:00:29] |
Although thinking about this some more, the way that we would be supporting this for the keyboard shortcuts probably would also work for the Trade Management by Study.
[2018-11-27 19:25:28] |
Hi. Looks like the Take Profit on 'Send attached orders' is working now using keyboard but not Stop Loss?
[2018-11-27 19:59:14] |
This will be supported in the next release.
[2018-12-04 10:49:40] |
Thanks for the take profit keyboard controls, they are working great now in the new release! You mentioned that the keyboard shortcuts probably would also work for the Trade Management by Study. Don't but my stop loss is not being moved after sending attached orders. Will this be possible still? Thanks S |
[2018-12-04 12:48:28] |
Ahh it's strange actually. It's working now. Maybe I had set something wrong. I'll monitor it for now, please ignore my last message
