Date/Time: Mon, 20 May 2024 13:32:31 +0000
ACSIL: Execute keyboard shortcut
View Count: 650
[2018-11-21 14:23:41] |
User654912 - Posts: 26 |
There are a lot of great menu functions that are unavailable to ACSIL such as "Hide Chart Drawings". Is it possible to add a function sc.ExecuteKeyboardShortcut(int ChartNumber, SCString KeySequence)? For example, KeySequence = "Shift+T" Thanks ps. I'm loving programming with ACSIL |
[2018-11-22 09:00:38] |
Well what we can do is instead add the necessary ACSIL functions that are required. Not a general one like you are saying. They have to be specific to perform a specific function.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-22 09:01:03
