Date/Time: Mon, 20 May 2024 17:01:38 +0000
New remote chart feature via DTC: data works, trading not
View Count: 954
[2018-11-21 13:53:18] |
JanS - Posts: 46 |
I refer to your thread about remote charts and your answer to my question there about trading a mapped symbol: Breaking Change: Remote Chart Data Files | Post: 164023 I can access market data but I can't trade the mapped symbol. I use two instances. SC1 (CQG) and SC2 (LMAX). I am mapping an CQG symbol to SC2 (LMAX). On SC2 (LMAX) I can access this symbol and its market data. But the trading window on SC2 (LMAX) only lists the LMAX account which makes sense, and I cannot trade a CQG symbol through an LMAX account. I know that trading SC1 (CQG) through SC2 (LMAX) would be possible if on SC2 (LMAX) I changed "Data/Trade Service Settings" from "DTC Subinstance". But then I could only trade CQG symbols on that instance and no longer any LMAX symbols. So if it is possible for me to trade the mapped symbol with CQG and all other symbols with LMAX in one single instance via symbol settings, then please tell me how. These are my symbol settings I used in SC2 (LMAX): <settings>
<symbol>F.US.GCEZ18</symbol> <symbol-srvcode></symbol-srvcode> <use-pattern-matching-characters>false</use-pattern-matching-characters> <description>GOLD FUTURES via DTC</description> <category>Custom</category> <value-format-code>1</value-format-code> <tick-size>0.1</tick-size> <currency-value-per-tick>10</currency-value-per-tick> <error-filtering>false</error-filtering> <default-order-quantity>1</default-order-quantity> <source-data-symbol>F.US.GCEZ18</source-data-symbol> <source-data-multiplier>1.0</source-data-multiplier> <generic-sub-client-server-address>127.0.0.1:11098</generic-sub-client-server-address> <realtime-data-client>Generic_Sub_Clients</realtime-data-client> <historical-data-server>127.0.0.1:11099</historical-data-server> <historical-daily-data-source>SC_DTC_HISTORICAL_DATA_SERVER</historical-daily-data-source> <historical-intraday-data-source>SC_DTC_HISTORICAL_DATA_SERVER</historical-intraday-data-source> </settings> |
[2018-11-21 17:27:57] |
So if it is possible for me to trade the mapped symbol with CQG and all other symbols with LMAX in one single instance via symbol settings, then please tell me how. Eventually this type of capability would internally be added, but it is unlikely something which would ever be exposed for end-users to use. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-22 00:19:39
