Date/Time: Sat, 15 Aug 2026 00:53:48 +0000
Adding the nyse tick and the nyse advance decline line below the price candlesticks, but in the
View Count: 2596
| [2013-11-04 18:44:28] |
| User37868 - Posts: 1 |
i have been trying since my trial started to get a chart of the spy of what i need, because i really like your service, but it´s extremely complicated. Now all I need is with in the same chart at the bottom, like if it was a volume study, I need to add the nsye tick (ticker symbol $tick) in the form of up and down lines showing the extremes +1000/-1000, but how do i add it to the bottom of the spy chart? And then the nyse a/d line symbol ($nhsf) in the form of candlesticks below the tick in the chart of spy as well. These are the studies that i use to determine if buyers or seller are in control of the market. Now can somebody please help me do this before my trial ends, so i can decide to keep your service permenantly. if you need to connect to my computer that is fine. I also need to know if it is possible to put studies at the top of the graph instead of the bottom. The ATR (average true range) for instance which i use to judge volatility. this is the chart that i have up always while i am trading stocks to help me judge market conditions. please help me
| [2013-11-05 01:57:26] |
To add the $ TICK or any other chart at the bottom of another chart, you need to use the Overlay (Bar) study. This is documented at the bottom of the page here: http://www.sierrachart.com/index.php?l=doc/helpdetails66.html Let us know if you need more help with this. It is possible to put studies at the top of the chart instead of the bottom, but there is an indirect procedure for this. It is not straightforward. It is kind of a workaround. As an alternative, you can overlay a study on to the main price graph by following the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_ChartStudies.html#OverlayingStudyOnMainPriceGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-11-05 01:57:42
