Date/Time: Fri, 03 May 2024 08:29:27 +0000
Problem with cyrillic symbols on the chart
View Count: 1712
[2013-11-04 15:26:21] |
Rex - Posts: 3 |
Hello! I have a problem with a text in cyrillic. When I use tool "Type Text" with cyrillic letters it doesn't display appropriately even with fonts that support cyrillic. http://www.sierrachart.com/image.php?l=1383578571726.png |
[2013-11-04 18:04:04] |
Most likely the problem is that the Cyrillic characters require more than one byte to represent them and since the text is held in single bytes, it will not display properly. There is no near-term solution to this. Longer-term, we may be able to solve this but it is not anything to wait around for. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-04 20:03:29] |
ganz - Posts: 1048 |
Rex FYI: [usr dscssn] a national charset for Tools and Tabs on Linux/Wine |
[2013-11-04 20:33:12] |
Rex - Posts: 3 |
Well, it's true for UTF-8 encoding. However with SC versions 9** and win XP I didn't have such problems. 2 ganz: Thank you, but I'm win7 user. |
[2013-11-12 08:50:07] |
Rex these are my settings for srv2008r2 and it does the job http://s14.postimg.org/6e3w4d6i9/cyr1.png |
