Date/Time: Mon, 20 May 2024 16:21:26 +0000
Renko chart backtesting
View Count: 1389
[2018-11-19 10:33:15] |
User513228 - Posts: 41 |
Hi, i noticed when i run backtesting on 1 tick renko chart i often get these error in trading service log: " Not evaluating trade signals because 500 or more bars have been added at once. " I tried change to 10 tick renko but there is still same problem but not so often as in 1t. Sierra cant handle this or where is problem ? I think backtesing is not very accurate because this |
[2018-11-19 17:38:00] |
Yes, this is a safety feature. We will think about a possible solution.
[2018-11-23 06:32:37] |
In the next release this limit will be increased to avoid this kind of problem. Hard to believe though you would encounter this though on a 10 tick Renko chart. This is a lot of bars added at once during a back test.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-23 06:33:26
