Date/Time: Thu, 02 May 2024 21:24:17 +0000
Proposal for a new indicator
View Count: 1523
[2013-11-04 09:11:07] |
User39404 - Posts: 1 |
Hello, at first - I commend you for a very successfully programed Sierra Chart! I was a user of Ninja Trader and differences in favor of the Sierra are large. I have a proposal for a new indicator - volume opacity in price chart. If you can program simple indicator that plots the bar volume along the bottom of the chart instead of in a separate panel. It saves a lot of horizontal space by not adding another panel to the chart. For better use would be great, if the setting include adjustable maximum volume bar height (percent of chart window or pixel) and opacity. I attach a screenshot, as I was accustomed to in the past. Thank you very much and have a great day. Jan |
volume_in_price_chart.PNG / V - Attached On 2013-11-04 09:10:54 UTC - Size: 141.44 KB - 552 views |
[2013-11-04 20:18:30] |
Thank you for the comments. We will have to look at this later on. This is fairly involved to implement. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-04 21:12:19] |
User14266 - Posts: 225 |
+1
[2013-11-05 07:16:08] |
normal guy - Posts: 16 |
+1
