Date/Time: Mon, 06 May 2024 08:01:29 +0000
bitstamp feed missing data
View Count: 1827
[2013-11-03 17:06:36] |
User31244 - Posts: 8 |
Hi, My Bitstamp feed is missing data. I've tried "Delete all data and download" and the data is still missing. I know it was Bitstamp's feed that went down, but do you have plans to recover the missing data? I'm missing: 10/18 19:00 thru 10/19 20:00 10/24 19:00 thru 10/25 14:00 10/25 19:00 thru 10/26 20:00 10/27 11:00 thru 10/27 13:00 There are a few other time periods less than one hour that are also missing data, but those listed above are big gaps. Thanks. |
[2013-11-04 08:32:27] |
We will do our best to see if we can patch the missing data.
[2013-11-04 22:41:34] |
We have updated the interface to Bitstamp. They had changed there API. The most amount of historical data they provide is 1 day: https://www.bitstamp.net/api/transactions/ So we do not see a practical way to patch the missing data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
