Date/Time: Mon, 29 Apr 2024 10:27:25 +0000
test_64.dll (No study functions present)
View Count: 560
[2018-11-13 17:59:29] |
jsob - Posts: 33 |
The dll appears to compile successfully, but when I navigate to the Add Study screen, the dll appears with this message. This was not an issue for me with prior releases. I installed the latest version of the Visual C++ compiler, I also ran a Remote Build: same problem. Installed prerelease version 1841
[2018-11-13 18:58:15] |
We do not see how this is related to a new version. Make sure there is at least one study function in the source code that begins with scsf_.
