Date/Time: Tue, 07 May 2024 20:57:46 +0000
Request for Volume Drawing Tool...
View Count: 618
[2018-11-13 14:52:58] |
User138602 - Posts: 169 |
Hello, i make it short: being able to cycle through a control_bar's symbol list is usefull. Therefore its neat that lines drawn for one symbol get saved for the symbol only and dont reappear when switching the symbol. BUT!!! this doesnt work for the Volume Drawing Tool. This tool lets one handpick volume profiles...otherwise i would use The VbP indicator. So why would this manually drawn tool reappear on other symbols? Its there completely out of context. The request: Can we have this tool's drawings handled like normal lines? Best Regards |
[2018-11-13 18:22:08] |
We do not see how this can be easily supported because the manually drawn Volume Profile is added as a study so it needs to appear no matter what the symbol.
[2018-11-13 18:22:11] |
[2018-11-13 18:22:13] |
We do not see how this can be easily supported because the manually drawn Volume Profile is added as a study, so it needs to appear no matter what the symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-13 21:00:23
[2018-11-13 20:36:47] |
Am i right, that your answer includes the TPO profile STUDY? Bcause, well, its a study....you quite emphasised that. MERGIN profiles (chart's context menu for TPO profiles) does the job as good as the drawing tool in visualizing the informations i seek but it would also require specific datasets for each individual symbol. |
