Date/Time: Tue, 07 May 2024 09:02:02 +0000
QuoteBoard issues
View Count: 1163
[2013-11-03 10:17:22] |
stevel - Posts: 19 |
Hi, I think I've found a couple of issues with regards the QuoteBoard. I'm using SC 1040 on Windows 8.1 but the issues also occurred on the previous SC version. 1. Double clicking on a blank space in the quoteboard crashes SC. 2. 'Save All' from the main menu doesn't seem to save newly created Symbol Alerts. It appears new Symbol Alerts created via the QuoteBoard window only get saved when you exit SC. Issue 2 is more of an observation that I noticed after loosing all my newly created alerts because of the first issue. I can work around these issues now I know they are there. Regards Date Time Of Last Edit: 2013-11-03 10:18:29
[2013-11-04 17:28:40] |
Thank you for pointing these out. We will resolve these.
