Date/Time: Sat, 27 Apr 2024 21:58:08 +0000
[Programming Help] - How to Show ACSIL UserTools on Multiple Charts?
View Count: 797
[2018-11-13 14:29:43] |
BlakJak - Posts: 108 |
I created a study which uses UserTool to draw lines and rectangles on my chart. I noticed that those drawings were not copied over to my other charts when drawn (unlike my manually drawn lines and rectangles). How do I get tools drawn by Studies to be copied over without having to add the Study to each of those charts? |
[2018-11-13 18:30:58] |
This is not supported when using the feature to copy drawings from one chart to another. But it is possible to set a user drawn drawing to be added to a different chart as compared to the chart the study is on. Refer to: Using Drawing Tools From an Advanced Custom Study: s_UseTool::ChartNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-13 18:31:34
[2023-03-15 09:53:46] |
User907967 - Posts: 53 |
Hi, can one access drawings from another chart via ACSIL? Say I have chart 1 with a bespoke ACSIL study and chart 2 with generated drawings using the following: Tool.LockDrawing = true; Tool.AddMethod = UTAM_ADD_OR_ADJUST; Tool.TransparentLabelBackground = true; Tool.AddAsUserDrawnDrawing = true; Tool.AllowCopyToOtherCharts = true; On Chart 1, I've been fiddling with sc.GetUserDrawnChartDrawing whilst trying to navigate through the drawings on chart 2 but was unsuccessful. Any thoughts? |
