Date/Time: Wed, 08 May 2024 11:32:29 +0000
Text On Dominant Side Auction
View Count: 1905
[2013-11-03 04:16:40] |
mkata - Posts: 103 |
At bar time 10:41 on 10-31-13 the coloring feature for the Column 1 UP % only seems to work with the 75-100%, which seems to defy the logic of the auction #’s. Is this a bug or do I have something set up incorrectly? I'm using default Column 1 threshold percentages. http://www.sierrachart.com/image.php?l=1383451861195.png |
[2013-11-04 19:05:22] |
We are going to get back to you on this today.
[2013-11-05 05:50:10] |
The documentation for the Text Coloring Method Input is here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#TextColoring Refer to the description for Text on Dominant Side Auction. The coloring should be according to the documentation. Please examine and understand it. If it is not working as documented, we would need to get your Chartbook and a specific explanation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-05 14:34:10] |
OK, I examined the documentation in great detail and understand better how you have this set up. According to the instructions, you have the coloring interrelated such that: BV < AV = BV Down 0-25% AV > BV = AV UP 76-100%. When looking at the numbers in my screenshot (square highlight) the auction numbers on the dominant side are 13, 12, 23 which are not 76-100% greater than 12, 10, 22. However 12, 10, 22 are 0-25% less than 13, 12, 23 making it appear as though it is coloring the non-dominant side with precedence. The way I think of it is that dominant side should be the one with the greater volume and be colored based on its percentage UP or Down from the weaker volume number. Date Time Of Last Edit: 2013-11-05 14:34:49
Text on Dominant Side.png / V - Attached On 2013-11-05 14:34:46 UTC - Size: 118.31 KB - 376 views |
[2013-11-05 16:52:56] |
We will be reviewing this.
