Date/Time: Fri, 13 Nov 2026 17:19:41 +0000
Open Chartbook
View Count: 1152
| [2018-11-12 19:43:12] |
| User910998 - Posts: 1 |
Why do I only see 8 chartbooks when I go to open a chartbook? There should literally be hundreds if not thousands. I am going to file:open chartbook. Then, because I see only 1 chartbook under file type .cht, I am selecting all files. Under "all files" I only see 8. The chartbooks my friends are telling me to search for are simply not there. Please help. Trying to get started and get things configured properly. I appreciate your help |
| [2018-11-12 19:53:34] |
You will see the Chartbooks that you have. There should not be hundreds or thousands. That does not make sense. If you want someone to send you a Chartbook they have, then have them refer to: http://www.sierrachart.com/index.php?page=doc/FileSharing.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
