Date/Time: Tue, 28 May 2024 02:37:49 +0000
Fibonacci retracement levels rounded up points
View Count: 552
[2018-11-12 08:18:56] |
User449811 - Posts: 8 |
Just after updating to v1837 when running the Fibonacci retracement tools set to display points these are shown to the nearest point and not as decimal points. Setup to round up to nearest point is set off. Please refer to screenshot attached.
Sc-fib-retrace.png / V - Attached On 2018-11-12 08:17:27 UTC - Size: 62.22 KB - 241 views |
[2018-11-12 08:34:27] |
This has been resolved in prerelease 1840. Update instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
