Date/Time: Sun, 05 May 2024 16:48:48 +0000
change appearance of p/l on chart
View Count: 1313
[2013-11-01 20:13:36] |
User33681 - Posts: 37 |
Is there a way to have the p/l shown on the chart line as shown in sshot in the proposed format? |
Attachment Deleted. proposed object to show profit-loss on chart.png / V - Attached On 2013-11-01 20:13:26 UTC - Size: 12.66 KB - 486 views |
[2013-11-03 19:57:30] |
Actually, now that you point this out, the proposed format is really how it should be and we will change that in the next release.
[2013-11-03 20:01:18] |
Thank you. Do you know when that may occur? |
[2013-11-04 13:26:29] |
Also - will you consider leaving a few more spaces after the colon (:) should there be a loss the negative (-) can be seen clearly seen or make the text larger ?? Thanks for taking this under consideration.
[2013-11-04 17:47:53] |
This change is in the latest prerelease.
