Date/Time: Sat, 11 May 2024 17:54:22 +0000
Retracement Tool: No more indication of cents in Version 1837
View Count: 674
[2018-11-09 08:44:13] |
User882915 - Posts: 32 |
Dear Sierra Support Team, I downloaded the current version today (1837). I then noticed that the price labels of the retracement tool don't show the cents anymore, but only the dollars (showing only "1" in 6E and e.g. "60" in CL, instead of the previous exact pricing (which is important to me)). I can't find any option how to bring the cents back in the tool settings. Can you please enlighten me (should I have overseen an option to do that) or bring that detailed pricing back? Thank you very much in advance. Kind regards |
Attachment Deleted. |
[2018-11-09 12:21:29] |
Ufo de Jager - Posts: 16 |
Same problem here. Since a couple of days (running #1837) no decimals in the retrace tool.
[2018-11-09 14:06:27] |
User316362 - Posts: 210 |
Same problem... and when set to "round to TickSize" in global settings...it doesn't work either. Was showing actual number in decimal without the rounding to the nearest ticksize checked. It looks like label changed to "int" type.
Date Time Of Last Edit: 2018-11-09 14:17:06
[2018-11-09 17:29:43] |
John - SC Support - Posts: 31534 |
This has been fixed and will be out in the next Pre-Release - 1839. When it is available, you can update following these instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-09 18:05:48] |
Version 1839 has been released. This is a pre-release. Follow the instructions here to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
