Date/Time: Thu, 09 May 2024 23:17:05 +0000
method to switch
View Count: 645
[2018-11-08 22:30:18] |
User525733 - Posts: 126 |
Hi, Is there a way to turn a single instance of "trading system based on alert condition" study on/off without going through the study's setup? possible desirable solutions include: 1) making a dedicated on/off button for each "trading system based on alert condition" study 2) turning it on/ off based on logic condition of another study (including another "trading system based on alert condition" study) thanks |
[2018-11-09 02:41:54] |
Yes through Control Bar buttons: Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events But you need to modify the study to accomplish this. The source code is provided in the ACS_Source folder. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-09 03:05:58
