Date/Time: Sun, 19 May 2024 02:02:01 +0000
$SPX Not Updating
View Count: 721
[2018-11-08 21:09:24] |
skelcap - Posts: 139 |
Hi, I just purchased the S&P Indices Exchange Fee so I could have realtime $SPX (S&P 500 Index) but it is not updating at all.
[2018-11-08 21:11:27] |
You need to use the symbol $INX. The one you are using is on CBOE Indices.
[2018-12-03 02:42:03] |
I can only get $INX intraday series to go back to 2018/5/31. Is that a data limit? I tried deleting the file and redownloading
[2018-12-03 02:51:30] |
Refer to this section here: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
