Date/Time: Fri, 10 May 2024 00:53:52 +0000
IB server side trailing stop order place from SC
View Count: 576
[2018-11-08 04:17:31] |
User517452 - Posts: 27 |
Is it possible to place an IB server side (native) trailing stop order from SC, such that even the connection between SC and IB is broken, the trailing stop order will be still working at IB side?
[2018-11-08 04:46:38] |
No, fundamentally this is something we would never do.
[2018-11-08 05:10:02] |
OK. I see. So as long as SC is connected to IB well, the trailing stop orders will work as they're supposed to right? |
[2018-11-08 05:10:52] |
Yes.
