Date/Time: Fri, 10 May 2024 00:03:48 +0000
Volume profile resetting/disappearing after settings are opened
View Count: 665
[2018-11-07 20:07:26] |
User502498 - Posts: 33 |
I had a full volume profile and then I clicked settings and it looks like it "started over". It will draw again, until I open the settings and then it erases it self. I'm on the latest version. |
unknown.png / V - Attached On 2018-11-07 20:06:47 UTC - Size: 193.43 KB - 258 views |
[2018-11-08 01:05:11] |
We do see this issue and we will have this resolved with the next release. We will see if we can have it out today.
[2018-11-08 01:39:16] |
We have a new release out now. This problem is now resolved in 1837.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-08 01:39:21
