Date/Time: Sat, 11 May 2024 16:14:22 +0000
sc.SaveChartImageToFileExtended function - how to disable reports to MessageLog
View Count: 621
[2018-11-07 09:21:24] |
User517260 - Posts: 97 |
Dear Support, I use sc.SaveChartImageToFileExtended function to make snapshots of chart. Every snapshot generates report to MessageLog like shown on attached screenshot. But I need to desable this outputs - this is unwanted information in MessageLog. How I can disable reports "The chart image has been saved to: ..." to Log? Thanks! Waiting for your reply, Alex.
ToSupport.jpg / V - Attached On 2018-11-07 09:14:24 UTC - Size: 132.23 KB - 292 views |
[2018-11-07 19:23:25] |
It is not supported to disable this.
[2018-11-08 07:17:59] |
Thanks!
