Date/Time: Mon, 13 May 2024 06:28:05 +0000
Auto Scale with Range
View Count: 749
[2018-11-06 14:29:11] |
User119530 - Posts: 15 |
Is it possible to have automatic scaling, to keep the high and low visible one the chart, but have a range as well? Sometimes the chart gets really stretched when you have a small range, say 3 points. I want to then set a range scale of 10 to keep it compressed.
[2018-11-06 19:14:07] |
No, but have a look at using the Interactive Scale Range feature: http://www.sierrachart.com/index.php?page=doc/Scaling.html#InteractiveScalingExpandCompress Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
