Date/Time: Fri, 10 May 2024 00:22:12 +0000
What's difference between calling chart studies list by F6 and by context mouse button?
View Count: 808
[2018-11-04 19:29:24] |
User517260 - Posts: 97 |
Dear support, I've got a problem - if I press F6? entry into my study settings, change values and then press apply button - everything is good - I see changings on chart. If I use right mouse button to call context menu Study Settings -> MyStudy, change same settings and then press apply button - I can't see changings on chart if subgruphs had to be cleared by internal logic of study. If after it I press "F6 - Enter" - chart is updating and draw new correct picture. Please look at this video https://youtu.be/_aZbK7MfJSo Could you help me with this? Thanks, Alex.
[2018-11-04 21:58:01] |
When you press the Apply button there is a recalculation of all studies on the chart even when you have opened the Study Settings window directly from the chart for the study. You can verify this by just altering another built-in study. So what the problem is in your case, we do not know. You will need to look into your own studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-07 09:10:35] |
Thanks!
