Date/Time: Sat, 04 May 2024 15:30:27 +0000
Problem with Attached Orders
View Count: 681
[2018-11-01 14:18:37] |
Meklon - Posts: 217 |
Hello Support, I am struggling with making Attached orders working correctly. The configuration on the Trade Window is quite simple (please see attached images): 1. 1 Target Limit 2. 1 Stop Limit When I place an order the Target and Stop are executed correctly. However, when I try to scale out (exit part of position), the originally placed Stop Limit and Target NOT adjusting according to the remaining number of the contracts (please see attached image). Example: 1. Original order - short 10 ES (Stop 6 ticks, Target Limit 12 ticks) 2. Scale out - buy 7 contracts at a profit (position remains 3 short) 3. Problem - Stop Limit and Target Limit are NOT adjusted to reflect remaining number of constructs (should adjust automatically to 3 but still remain 10) Anything I do incorrectly or missing a part of configuration to make this work properly? |
AO-Stop.png / V - Attached On 2018-11-01 14:17:39 UTC - Size: 16.44 KB - 226 views Problem.png / V - Attached On 2018-11-01 14:18:16 UTC - Size: 162.78 KB - 249 views |
[2018-11-01 19:27:26] |
Enable confirmations and you should see a dialog like the attached indicating scaling out is being used. And make sure you have enabled the scaling out option on the correct Trade Window: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#TradeWindowSettingsNotApplyingToChartOrTradingDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
2018-11-01_122525.png / V - Attached On 2018-11-01 19:26:26 UTC - Size: 11.58 KB - 247 views |
[2018-11-03 20:34:14] |
Thank you support, the problem was Scale In / Scale Out was disabled.
