Date/Time: Sat, 18 May 2024 02:38:31 +0000
numbers bars transparent volume profiles
View Count: 980
[2018-11-01 13:26:08] |
User884550 - Posts: 149 |
is it possible to add transparency functionality to volume profiles on numbers bars columns? so that it would be barely visible behind the actual values, same as it is in VbP study |
[2018-11-01 19:22:22] |
This is not something we can get to any time soon. The option available is to use an Outline Background Type.
