Date/Time: Wed, 08 May 2024 01:23:52 +0000
Point of Control
View Count: 2610
[2013-10-31 20:05:51] |
Are you looking for the volume point of control of every two bars?
[2013-11-01 16:07:48] |
Use the Volume by Price study: http://www.sierrachart.com/index.php?l=doc/doc_VolumeByPrice.html The study has an input to enable the highlighting of the Point of Control. You will want to set the Volume Graph Period Type input to One Period of Fixed Bar Count. Set the Number of Bars for Fixed Bar Count input to what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-13 20:25:08] |
Manerva Funding Financial - Posts: 16 |
The point of control is changing throughout the day. Is there a way to have a line drawn for the prior point of control area once it has changed?
[2023-01-13 21:25:25] |
Sierra_Chart Engineering - Posts: 14263 |
We just want to confirm what study you are using?
[2023-01-15 07:12:19] |
I am using Vbp study
[2023-01-15 15:47:19] |
In this case you need to set this particular Input to Yes: Volume By Price Study: Calculate Developing POC and Value Area Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-15 18:13:22] |
Thank you so much for your assistance. Looks like I already had the option on yes. However, I still don't see where it identify's the last point of control before it changed to the final point of control. I looked at the Chart values window and chart value tools both only show the final POC for day but not lets say what was the POC at 12 noon before it changed. Or the largest percentage of volume before the final POC is the last POC is what the study shows?
[2023-01-17 21:23:12] |
We apologize we forgot to provide this information. You need to follow the instructions here to actually see the Point of Control line historically: Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-17 21:41:16
[2023-01-19 08:41:48] |
I followed the instructions and did not see any changes in the chart.
[2023-01-19 08:42:44] |
when I choose the choices of standard deviation none of them show up on the char.
[2023-01-19 15:46:20] |
John - SC Support - Posts: 31441 |
We think you are referring to "Standard Deviation Bands" as noted in the Input for Calculate Mean Price and Standard Deviation Bands. Refer to the information for this Input that explains how to view the information, at the following link: Volume By Price Study: Calculate Mean Price and Standard Deviation Bands For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
