Date/Time: Tue, 07 May 2024 10:17:18 +0000
MP Session End Issues
View Count: 1153
[2013-10-31 18:55:23] |
Profile Trader - Posts: 168 |
When I have a CL MP chart up set to 9am to 2:30pm (pit session time) as it closes at 2:30pm I get an additional print of the 2:30 to 3:00 pm session(L period) on my chart. If I switch to show after hours trading the L period will revert to the correct profile. I have attached several screen shots to better explain what I am talking about. As you can see just the print of the L period after the 2:30pm close changes my POC by 12 points in this specific day. I am using 1040 build. I have also deleted all data and reloaded several times as well. Thanks, Doug Date Time Of Last Edit: 2013-10-31 19:17:33
CL MP 24 Hour Session.bmp - Attached On 2013-10-31 18:54:09 UTC - Size: 2.39 MB - 427 views CL MP Pit Session.bmp - Attached On 2013-10-31 18:54:17 UTC - Size: 1.79 MB - 396 views CL Chart Settings.png / V - Attached On 2013-10-31 18:54:25 UTC - Size: 84.74 KB - 376 views |
[2013-10-31 19:20:27] |
The solution to this is to set the End Time to 14:29:59 in Chart >> Chart Settings.
