Date/Time: Wed, 08 May 2024 23:11:43 +0000
Custom Trading Keyboard Shortcuts
View Count: 6211
[2018-10-31 12:56:56] |
User716575 - Posts: 24 |
Hi, Is it possible to create a trading shortcut key to toggle price for a limit or stop order. Instead of using limit/stop +- 2, 3 or more. Being able to choose price up or down the dom. I have been able to do this with many equity platforms. John |
[2018-10-31 19:41:58] |
Refer to these custom keyboard shortcuts here: Basic Trading and the Trade Window: Custom Trading Keyboard Shortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-01 21:11:51] |
I understand how to set up the customize keyboard shortcuts. There is no option there to toggle price up or down. I would like to be able to pick a specific price without using the Dom,just using hotkeys. This option is available on most equity platfoms. Usually as a pop up box to toggle price. Is it possible to program this function. John |
[2018-11-01 21:18:07] |
Are you referring to being able to modify the price of an existing order , by using a keyboard shortcut?
[2018-11-01 23:45:32] |
Once in a position being able to place a limit and stop order to exit. So If I enter CL at 63.60 long I can limit out above and place a stop below at my disired price using hot keys instead of using the dom with a mouse. |
[2018-11-02 20:03:38] |
Hi, I never heard back from my last reply John |
[2018-11-02 23:45:49] |
The closest that is available is to use the Attached Order functionality: Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-11-03 18:26:05] |
Ok thanks for the feedback. Would creating a hot key with a price toggle box be a feature Sierra may consider adding? John |
