Date/Time: Sat, 18 May 2024 06:48:41 +0000
Replay Chart command unresponsive - [Solved]
View Count: 551
[2018-10-31 08:15:12] |
User877753 - Posts: 152 |
Hi, I have been replaying part of previous session almost every day for months. Got an issue with the latest 1833 SC : When hitting Chart >> Replay Chart >> Replay Chart (control panel, usually the control pops up. That's not the case with SC 1833. Could you help me ? Regards, Edit : I downgraded to 1828, which I used to replay last week end, and the issue persists, even lanuching SC in safe mode. So it shouldn't be a version problem, but a specific issue to my own setting. Any advice ? Edit : Found the solution here : Replaying Charts: Chart Replay Window Not Visible Everything fine now. Date Time Of Last Edit: 2018-10-31 14:20:10
[2018-10-31 17:34:43] |
Yes this is the relevant documentation: Replaying Charts: Chart Replay Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
