Date/Time: Sat, 18 May 2024 09:54:16 +0000
Replay has gotten very slow
View Count: 1128
[2018-10-30 18:01:06] |
User48838 - Posts: 112 |
when I replay ESZ18 with Accurate Trading and a speed of 59 on a single chart, the replay is VERY slow. This is a recent issue, it takes almost an hour to replay an hour. The replay function seems to work ok when Standard Replay is ON but my program doesn't record the correct entries at this speed.
replay settings.png / V - Attached On 2018-10-30 18:00:45 UTC - Size: 19.07 KB - 243 views |
[2018-10-31 18:16:22] |
That really is not surprising for it to be slow when using Accurate Trading System Back Test Mode. Usually the problem relates to studies. But it really should not take an hour though to replay an hour. Refer to the documentation here: Auto Trade System Back Testing: Improving Back Test Performance Also this definitively is not a recent issue. There is another explanation for this problem you are having. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-31 18:16:40
