Date/Time: Sat, 18 May 2024 09:06:03 +0000
Export files of trades
View Count: 1543
[2018-10-29 18:19:30] |
JDMontero - Posts: 34 |
Hi, I‘m having a problem exporting trading files. I am in Costa Rica, CST (Central America), and I see my charts well aligned with the hour in my computer. However -When I export trading files, the time is OK in the activity Log, but when I open the file in my computer, I see the time and it is out of whack. -I see a dissonance between the time on top of the window of my main window chart, but the computer time is set correctly. Please advise. I‘m exporting files to tradervue for a mentorship and need to get the export files with accurate fill times to get certain stats. |
[2018-10-29 18:27:34] |
-When I export trading files, the time is OK in the activity Log, but when I open the file in my computer, I see the time and it is out of whack. -I see a dissonance between the time on top of the window of my main window chart, but the computer time is set correctly. We do not understand this. What are you comparing to? Provide specific details.
[2018-10-31 00:17:58] |
Ok so... I adjusted SC time settings to my time zone, which is Costa Rica, Central America (-6 UTC) Adjusted the Data/trade settings https://www.screencast.com/t/hSxrXlgXNx And adjusted chart settings https://www.screencast.com/t/Fzc0RcYg When I want to export my trades, I go to activity log, and everything seems fine. Time of each trade is OK. https://www.screencast.com/t/dtl8JUtBzWe But when I open the file downloaded to my desktop, time suddenly changes! And needs the -6 on each of the times of the trades. Every trade has +6 hours on the time at which I executed. https://www.screencast.com/t/lFH3zIetsUco Please advise. Regards. |
[2018-10-31 22:02:37] |
For an understanding of the Date-Times, refer to: Trade Activity Log: Importing and Exporting Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
