Date/Time: Sat, 18 May 2024 09:54:23 +0000
Use Evening Session Setting Change When I change the symbol for the Chartbook
View Count: 643
[2018-10-27 22:02:37] |
User260560 - Posts: 37 |
Hi there, I have a chartbook with many charts. Whenever I change the chart symbol, some of the charts with ETH data always automatically switched to only RTH data(use evening session goes unchecked from checked), so I had to always switch the setting back. I updated to the latest version, but still couldn't figure out how to keep the session time setting remain the same when I switch the symbol for the chartbook...Please help, Thanks!
[2018-10-27 23:07:01] |
There are two solutions. Prevent the changing of Session Times as explained here: Global Symbol Settings: Setting of Intraday Chart Session Times Or in the Global Symbol Settings for the Symbol or symbol pattern enable the Use Evening Session Times option. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
