Date/Time: Sat, 18 May 2024 05:12:04 +0000
Data Feed
View Count: 748
[2018-10-26 21:58:46] |
User445529 - Posts: 4 |
Hello, > > Am planning to purchase sierra, kindly can you advice me the below details. > > 1. India Intraday along with EOD even if it is delayed for 15 minutes is it available? and how much it cost. > 2. Overall how much I need to pay for Sierra along with Indian data feed if am gonna use it for one month. > 3. In trial data feed do Indian data feed available. > > *Thanks,* > |
[2018-10-29 20:55:58] |
1. Only historical end of day data is available for the Indian markets. There is no additional cost. It is included with the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service We hope to be able to offer a full Real-time and trading solution for the Indian markets in 2019. We are working on this. 2. You just need to pay for Service Package 3 (Standard): Description of Service Packages and Pricing 3. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-29 20:56:18
[2018-10-30 18:36:48] |
Indian Data Feed is not working if you could help me with the steps much appreciated
[2018-10-30 18:57:23] |
We can only help you with accessing historical daily data for the Indian exchanges. Did you want to chart a particular Indian stock?
[2018-10-30 19:36:17] |
Can you help me with ACC.NS stock so that I can follow the same steps for other stocks
Date Time Of Last Edit: 2018-10-30 20:42:47
[2018-10-30 22:31:44] |
We were able to get a historical chart for that symbol: http://www.sierrachart.com/image.php?Image=154093868743.png Is that what you are looking for? There is not going to be Intraday data available. That will come sometime in 2019 we expect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-31 01:31:51] |
EOD is enough for me, but when I try to plot it is not working.
Private File |
[2018-10-31 18:18:17] |
The problem is that the Data folder Sierra Chart is using is restricted on your system. Refer to: Error Messages When Opening Files This is the relevant subsection that most likely will solve the problem: Error Messages When Opening Files: Restricted File / Folder Security Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-31 18:24:18
