Date/Time: Sat, 18 May 2024 06:22:39 +0000
Changing the displayed price
View Count: 551
[2018-10-26 16:16:46] |
User430337 - Posts: 1 |
How can I change the price range on the right hand column of the chart? For instance in CL the price displays in an increment of .04 cents - 67.88, 67.92, 67.96, 68.00, etc and I'd like to change it to display in increments of .03 cents. I'd like to change it in NQ and RTY as well. Thanks Date Time Of Last Edit: 2018-10-26 16:17:20
[2018-10-26 18:11:39] |
This can be done with the Scale Increment setting on the Scale Window: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
