Date/Time: Thu, 02 May 2024 17:26:27 +0000
Connection error with LMAX
View Count: 1113
[2013-10-31 13:40:01] |
batman_ - Posts: 190 |
Please advice how to solve connection error with LMAX. LMAX Trading: Connecting. | 2013-10-31 13:38:53 LMAX Trading: Connecting to Demo Trade server: fix-ate.lmaxtrader.com:443 | 2013-10-31 13:38:53 Resolved address fix-ate.lmaxtrader.com to IP 91.215.165.68 | 2013-10-31 13:38:53 The network socket is connected. | 2013-10-31 13:38:53 The socket starting SSL connection. | 2013-10-31 13:38:53 SSL socket is now connected. | 2013-10-31 13:38:54 LMAX Trade FIX Session: Sending the Logon message. | 2013-10-31 13:38:54 LMAX Trade FIX Session: Received a sequence number that is ahead of the next expected sequence number. Resetting current sequence number to 38 | 2013-10-31 13:38:54 LMAX Trade FIX Session: Received a Logout message. Text = User not authorized | 2013-10-31 13:38:54 LMAX Trade FIX Session: Sending a Logout message. Text = Received Logout message. | 2013-10-31 13:38:54 The SSL socket was shut down successfully. | 2013-10-31 13:38:54 LMAX Trade FIX Session: Logged out and disconnected. | 2013-10-31 13:38:54 Error connecting to Data or Trading service. For help with this issue, press the Send For Analysis button on this window. | 2013-10-31 13:38:54 To prevent further connection attempts, select File >> Disconnect. | 2013-10-31 13:38:54 LMAX Trading: Disconnected from trade and market data servers. | 2013-10-31 13:38:54 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2013-10-31 13:38:54 Date Time Of Last Edit: 2013-10-31 15:30:48
[2013-10-31 17:17:49] |
This is the relevant error message: LMAX Trade FIX Session: Received a Logout message. Text = User not authorized | 2013-10-31 13:38:54 This is explained at step 13 here: https://www.sierrachart.com/index.php?l=doc/LMAX.php#Setup Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-10-31 17:18:09
