Date/Time: Sat, 18 May 2024 08:23:18 +0000
study/method to control other trading studies
View Count: 543
[2018-10-26 10:55:14] |
User525733 - Posts: 126 |
Hi, Is there a study that can do the following: when signal X is true --> use BuyEntry trading system 1 and attached order settings 1 when signal X is false --> use BuyEntry trading system 2 and attached order settings 2 (BuyEntry trading system is basically SC's trading system based on alert condition study) thanks |
[2018-10-26 18:09:27] |
For something more advanced like this you need to use the Spreadsheet System for Trading study: Spreadsheet Systems, Alerts and Automated Trading And that study does give you the ability to set the Target and Stop order offsets directly on the Sheet. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-26 19:12:23] |
"And that study does give you the ability to set the Target and Stop order offsets directly on the Sheet." can i change Target and Stop using the spreadsheet sys at runtime? |
[2018-10-26 20:01:02] |
Yes you can.
