Date/Time: Sat, 18 May 2024 12:27:28 +0000
copy drawings from another chartbook
View Count: 1892
[2018-10-26 07:22:37] |
User884550 - Posts: 149 |
what could be the reason my chart does not copy drawings from another open chartbook for the same symbol?
[2018-10-26 17:50:58] |
The first thing to check is that you are using the correct format for copying drawings from another chartbook. You need to specify the Chartbook and Chart using the following format Chartbook2:3 where Chartbook2 is the name of the Chartbook and 3 is the Chart number. Refer to the following, particularly the 4th paragraph: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-26 17:51:40
