Date/Time: Sat, 18 May 2024 06:49:02 +0000
Point and Figure Charting Study doesn't seem to work
View Count: 718
[2018-10-26 00:02:34] |
jsmanuse - Posts: 32 |
I have tried several ways to use the point and figure charting and the only way I can get it to show up is by using Chart Settings > then selecting the point and figure options there. There is no other information about this study however. Is there any other support information available. I have attached an image of what it shows me. http://www.sierrachart.com/image.php?Image=1540511968217.png |
[2018-10-26 07:41:44] |
We have released a new revision of 1829. Update with Help >> Download Prerelease to resolve this.
[2018-10-26 13:09:10] |
Downloaded and installed the new version... http://www.sierrachart.com/image.php?Image=1540559273414.png Still doesn't work. |
[2018-10-26 17:58:45] |
You needed to install the pre-release. You are still running 1828. At this time we have released 1830 which is now the main release. Update again.
